Home > Td5 > Vented disc upgrade |
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 81 |
Hi all
1. Vented disc upgrade - is it worth it? 2. is it just a case of changing discs and calipers? Any other bits needed apart from pads/fitting kit? Cheers |
5th Apr 2020 8:02pm |
Yes
Yes. No. |
5th Apr 2020 8:26pm |
Any brake upgrade is good.
I forgot to say hi. Hi. |
5th Apr 2020 8:28pm |
Thanks chaps - bits ordered!
6th Apr 2020 7:52pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
I’ve got a decent pair of front vented calipers for sale if interested also have good rear pair for 110 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
6th Apr 2020 7:57pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
I do a fluid swap while your at it
7th Apr 2020 10:31am |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 531 |
Could you pm me pics and a price inc delivery to AB54, and what were they off as to fit my 05 110 td5 |
7th Apr 2020 10:49am |
Thanks - mate has given me some new old stock calipers I'll replace the seals and give them a go.
Any good guides anywhere on how to check CV joints for wear? think mine are knackered. Are the copies any good or should I go OEM/GKN? Cheers |
10th Apr 2020 4:18pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8059 |
Or you can add the spacer and o rings to make a std caliper wider. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Apr 2020 5:22pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
WHy do you think CV joints are worn? Clicking on full lock? They generally wear out after other bits of the driveline due to being relatively protected and well oiled inside the swivel housing. Mine are 200k miles old and still nice and tight! |
10th Apr 2020 5:50pm |
Yes they do click on lock but also holding shafts either side and twisting there is play.
10th Apr 2020 7:45pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Holding the shafts on either side of the CV joint or either side off the whole axle? The last will be diff play I think. My CV never got worn they just broke:
http://www.youtube.com/watch?v=NpB1HKRpTzc At about 50 seconds Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Apr 2020 5:08pm |
