Home > Td5 > Vented disc upgrade
Rich1968
Vented disc upgrade
Hi all
1. Vented disc upgrade - is it worth it?
2. is it just a case of changing discs and calipers?
Any other bits needed apart from pads/fitting kit?
Post #823548 5th Apr 2020 8:02pm
Yes
Yes.
No.
Thumbs Up
Post #823552 5th Apr 2020 8:26pm
Any brake upgrade is good.
I forgot to say hi. Hi.
Post #823554 5th Apr 2020 8:28pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I've just done this on my 90. Yesterday!
Not had chance to drive it with the lockdown restrictions,so,I'll report back when I've got a few miles on with the vented discs,we'll see if there is any improvment.
I used to get brake fade on some of the long decents in the Pyrenees,so,if nowt else,I'm hoping the vented discs should cool down a bit quicker so reduce fade.
Marc.
Post #823711 6th Apr 2020 4:28pm
Rich1968
Thanks chaps - bits ordered!
Post #823758 6th Apr 2020 7:52pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I’ve got a decent pair of front vented calipers for sale if interested also have good rear pair for 110 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #823764 6th Apr 2020 7:57pm
isacs
I do a fluid swap while your at it
Post #823858 7th Apr 2020 10:31am
htb2
Wales
Could you pm me pics and a price inc delivery to AB54, and what were they off as to fit my 05 110 td5
Post #823860 7th Apr 2020 10:49am
Rich1968
Thanks - mate has given me some new old stock calipers I'll replace the seals and give them a go.
Any good guides anywhere on how to check CV joints for wear? think mine are knackered.
Are the copies any good or should I go OEM/GKN?
Post #824429 10th Apr 2020 4:18pm
jst
Or you can add the spacer and o rings to make a std caliper wider. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #824438 10th Apr 2020 5:22pm
miker
WHy do you think CV joints are worn? Clicking on full lock? They generally wear out after other bits of the driveline due to being relatively protected and well oiled inside the swivel housing. Mine are 200k miles old and still nice and tight!
Post #824449 10th Apr 2020 5:50pm
Rich1968
Yes they do click on lock but also holding shafts either side and twisting there is play.
Post #824473 10th Apr 2020 7:45pm
roel
Holding the shafts on either side of the CV joint or either side off the whole axle? The last will be diff play I think. My CV never got worn they just broke:
http://www.youtube.com/watch?v=NpB1HKRpTzc
At about 50 seconds Roel
2003 90 Td5 (2009-now)
Post #824617 11th Apr 2020 5:08pm
