Home > Puma (Tdci) > Headlights not working...
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Puma 2.2 MY2012
I have searched the forum, but could not find it Smile
Both headlights are not working
When I switch them on I can clearly hear the relais under the seat (checked it by pulling it out and canged with another, but did not help). The smaller daylights do work in both positions.
Whem I use the indicator to flash it is working.
Please help
Regards
Quirin
Post #823452 5th Apr 2020 11:13am
Devon-Rover
have you checked the relay under the dash access panel that feeds the underseat one? Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #823465 5th Apr 2020 12:38pm
TopQ1967
Hi D-R,
I supose The under seat relay will not click when the under dash is not working..
So it must be in between the under seat relay and headlights.
Post #823508 5th Apr 2020 5:59pm
Devon-Rover
Post #823528 5th Apr 2020 7:39pm
Mongolia
France
[quote="TopQ1967"]Hi D-R,
So it must be in between the under seat relay and headlights.[/quote]
May be, the light switch to replace?
Post #824942 13th Apr 2020 11:10am
ickle
I wasn't aware the headlight circuit had a relay - hence the common fault of a burnt out column switch and the aftermarket headlight looms with relays that take the load off the column switch - unless LR in their wisdom fitted relays to the last few years of production.....?
Post #825025 13th Apr 2020 6:53pm
There has always been one relay, which ensure that the headlights are extinguished if you turn off the ignition, however it doesn't prevent the entire headlamp current being passed by both the light-switch and the dip-switch, hence the common failures of both/either switch.
I believe that very late models may have improved wiring, but I have never come across one.
Post #825114 14th Apr 2020 8:43am
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Jops, the wiring was changed with MY12 to use a relay, which prevents the switch from too much current.
Post #825631 15th Apr 2020 9:23pm
TheGrumpy
Australia
Hi Quirin, did you get a fix for the lights?
I’ve got a MY16 starting to play up the same way!
Post #844844 20th Jul 2020 12:24pm
