Home > Maintenance & Modifications > Underbody protection?
bear100
The time has come to look into underbody protection for the expedition build Very Happy
This is a first for me and im looking for advice on what too use, mostly general expedition use and nothing to heavy in the way of offloading is likely
Essentially I'm looking at a steering guard and diff guards, looks have to play a part as well, after all its my pride and joy!
I like the look of the Bowler steering guard but it's very pricey
im sure I've have heard in the past to avoid certain guards for various reasons?
any way what's your thoughts and experience Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #823081 3rd Apr 2020 8:29am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
On my 90 I’ve got an 8mm aluminium steering guard and a 6mm aluminium fuel tank guard. The steering guard was about £120 from memory and was the thickest I could find. It’s done very well over the last couple of years. The tank guard was a pig to fit and required extensive drilling to make the guard line up with the chassis. I haven’t hit it on anything yet, I don’t think, but it looks good if nothing else! I think it was about £90.
I also have a set of Uproar 4x4 stainless tree sliders fitted. They weren’t cheap but they’re mega strong, will outlast everything else, and look brilliant. Thumbs Up Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #823089 3rd Apr 2020 8:56am
If the build is a TDCi, don't forget that the most important piece of underbody protection of all is the fuel cooler guard.
Post #823091 3rd Apr 2020 8:59am
Pilgrimmick
If for remote travel, then avoid alloy as can be difficult to get welded if you have problems. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #823099 3rd Apr 2020 9:47am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Any links to a fuel cooler guard please Blackwolf?
Post #823113 3rd Apr 2020 10:46am
discomog
Just Google "Fuel cooler guard Land Rover Defender" and you'll see loads for sale. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #823115 3rd Apr 2020 10:51am
Joe the Plumber
Doh! That's got it. Many thanks.
Post #823119 3rd Apr 2020 11:19am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
And aluminium auto case-hardens on impact - so it can be difficult to reshape or remove when damaged (i.e. done its job!)/ JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #823130 3rd Apr 2020 12:53pm
bear100
Thanks chaps, that is what makes forums invaluable!
Fuel cooler added to the list Thumbs Up
I’m also one of those who likes to have matching set ups (I wouldn’t be able to sleep if I had one tyre different to the others!)
Ok I was initially looking at ali but didn’t realise it’s downfalls some good points about auto case hardening and find it difficult to have welded when the inevitable happens.
I suppose stainless would be the best bet then? Got enough on my hands with corrosion as it is! 2016 Range Rover Autobiography 4.4 TDV8
Post #823133 3rd Apr 2020 1:10pm
Lodelaner
Zinc finish is pretty good - look at the D44 Clubman steering guard. Looks ok, 5.5mm thick, 3 piece, well designed.
You could always paint it if you like Smile JB
Post #823134 3rd Apr 2020 1:17pm
I've been very pleased with my Safari-Equip steering guard.
https://www.safari-equip.co.uk/land-rover/...d-pin.html
Post #823143 3rd Apr 2020 2:11pm
Devon-Rover
Whistle Thumbs Up Cool Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #823166 3rd Apr 2020 4:41pm
Mantec Dural one on my 110, works a treat and looks good (a la camel trophy)
I've also got a southdown steel axle guard; the large plate that bolts to the radius arm bolts.... very nice but interferes with the anti roll bar joints. When my plasma cutter is mended I'll cut a couple of holes out of it for the bottom of the joints to rest in.
Post #823192 3rd Apr 2020 6:16pm
Jem_90
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
Hi, I went for terrafirma fuel cooler, steering guard and transmission guard. Very happy with choice.
Post #823345 4th Apr 2020 7:27pm
jst
Steering can be the hardest thing to fix but is essential for any movement.
Gwyn Lewis heavy duty sumo bars drag and track rod. It would be beneficial fitting the track rod end arrangement to the drop arm too, these are far easier to change when out and about.
The southdown guard gives great diff and track rod protection. Or try the gwyn track rod box section. That with sumo bars works very well.
Also think fuel protection for the tank if in stumps or rock areas. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #823353 4th Apr 2020 7:53pm
