![]() | Home > Maintenance & Modifications > Winchmax vs Rhino winches |
Hi all
Anyone got experience or advice with these manufacturers? I've got a Winchmax bumper I'm very pleased with but can't decide which winch manufacturer to go for. I only need a small winch (13000 lbs) for carefully dragging caravans/trees/myself etc. out of crap. Synthetic cord is fine. These two have very similar specs but the second is 150 Euros cheaper: ![]() Click image to enlarge ![]() Any ideas? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Winchmax is what I’ve fitted and am very very very happy with it. Nicely made, and looks that last unlike previous winches.
You should a got winch with bumper as they do package deal. They also sell a defender wiring kit which is good quality. Give them a call and ask for a deal. I did ![]() ![]() |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
I fitted a Rhino with wire cable.....not really used it in a vengeance but I am very happy with it.....worked perfectly in all my tests.... price was right and delivered the day after ordering!
Good luck Rob ![]() Click image to enlarge |
Okay - not a "small" winch exactly but pretty much the smallest I can get away with
![]() Thanks Andy, thanks G4UJS. It was only after I saw how good the Winchmax bumper was (and how quickly delivered) that I decided to upgrade the towbar winch as well. I'll wait for a few more replies but the Winchmax or Rhino are definitely the "defaults". ![]() But shout it at them in German because life is also terrifying and confusing... |
![]() Click image to enlarge I went for a second hand Warn, now with a XP motor and different relais. The problem I see with most budget winches is that they quote high line pulls but I doubt if they make that happen. Mine should pull 9000 lbs with the original motor but is a lot quicker than the budget winches and I have a feeling that it is stronger too. Most time winches give problems if they are not used enough. Connections start corroding and that gives heat and resistence so more heat and a not working motor after a short while. If a permanent magnet motor gets to hot the magnets break and it is over. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
