Home > Maintenance & Modifications > Winchmax vs Rhino winches
ZeDefender
Hi all
Anyone got experience or advice with these manufacturers? I've got a Winchmax bumper I'm very pleased with but can't decide which winch manufacturer to go for.
I only need a small winch (13000 lbs) for carefully dragging caravans/trees/myself etc. out of crap. Synthetic cord is fine.
These two have very similar specs but the second is 150 Euros cheaper:
Any ideas? Tell someone you love them today because life is short.
Post #822208 30th Mar 2020 8:46am
13,000 lbs is not a small winch!
Compare with the king of winches, the Husky, rated at 8,000 for the standard model.
Post #822214 30th Mar 2020 9:32am
landy andy
Winchmax is what I’ve fitted and am very very very happy with it. Nicely made, and looks that last unlike previous winches.
You should a got winch with bumper as they do package deal. They also sell a defender wiring kit which is good quality. Give them a call and ask for a deal. I did Thumbs Up Thumbs Up
Post #822217 30th Mar 2020 9:46am
landy andy
Post #822219 30th Mar 2020 9:47am
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I fitted a Rhino with wire cable.....not really used it in a vengeance but I am very happy with it.....worked perfectly in all my tests.... price was right and delivered the day after ordering!
Good luck
Rob
Post #822229 30th Mar 2020 10:31am
ZeDefender
Okay - not a "small" winch exactly but pretty much the smallest I can get away with Wink
Thanks Andy, thanks G4UJS. It was only after I saw how good the Winchmax bumper was (and how quickly delivered) that I decided to upgrade the towbar winch as well.
I'll wait for a few more replies but the Winchmax or Rhino are definitely the "defaults".
Thumbs Up Tell someone you love them today because life is short.
Post #822230 30th Mar 2020 10:32am
roel
I went for a second hand Warn, now with a XP motor and different relais.
The problem I see with most budget winches is that they quote high line pulls but I doubt if they make that happen. Mine should pull 9000 lbs with the original motor but is a lot quicker than the budget winches and I have a feeling that it is stronger too.
Most time winches give problems if they are not used enough. Connections start corroding and that gives heat and resistence so more heat and a not working motor after a short while. If a permanent magnet motor gets to hot the magnets break and it is over. Roel
2003 90 Td5 (2009-now)
Post #822244 30th Mar 2020 11:27am
