Home > Maintenance & Modifications > Best stick on sound proofing
Page 1 of 3 123>
jst
What's the consensus on best value for money sound deadening I can stick the rear seat box of a double cab? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #821348 25th Mar 2020 11:17pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Guess anyone would advice on the stuff they stuck on themselves?
Not sure what's the best value but I've bought a complete sound deadening kit from a forum member (mps?) years ago. After only covering the rear behind the rear seats with Dynamat Xtreme and Dynaliner it already made such a difference I never fitted the rest.
Who knows if I get bored enough during lockdown...
Post #821354 25th Mar 2020 11:29pm
PCM
Silent coat is far cheaper then dynamat but still expensive. It’s cheaper if you buy in bulk and in sheets. Not pre cut.
Some people have used simple rubber mat but I can’t comment on the Results. Silent coat worked for me. recomended by the super helpful blokes at deadening.co..uk Thumbs Up
Post #821362 26th Mar 2020 12:02am
I like Dynamat Extreme in black but there are different alternatives such as above.
There was some talk about some of the cheap stuff possibly containing Lead, I don't know what truth there is in that though.
Dynamat may not be cheap but it works, I haven't done much of mine with it but the seat boxes externally and the base made a difference I do know.
One day I may do more, I've been telling myself that for about 4 years now. Laughing WeWillWin🇬🇧🇺🇸
Post #821379 26th Mar 2020 2:16am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I’ve used Fatmat on a few vehicles and it performs well. Much cheaper than dynamat too. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #821384 26th Mar 2020 7:58am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I bought sheets of dynamat and cut to size , it was also for a double cab . The difference is huge , doors, seat box and floors made were the most noticeable .
I like the dynamat because it doesn’t hold water , I’ve tried other brands and was hugely disappointed that they acted like sponges https://www.instagram.com/hustynminepark/
Post #821387 26th Mar 2020 8:08am
bankz5152
Fatmat megamat. Cheaper then dyna extreme and basically the same product.
Makes a huge difference, also added some layers of 6 and 3mm closed cell foam over the top.
Post #821389 26th Mar 2020 8:20am
There's a company on eBay - the Sound Deadening Shop or something similar - that sells bulk packs of Silentcoat cheaper than anywhere else that I've found. I've been very pleased with its' performance. Buy a cheap, wall paper seam roller to aid with installation.
If you're planning on using acoustic foam over the dense layer then buy generic unbranded stuff. I've used both Silentcoat branded and generic 6mm foam in two different vehicles and whist there was a slight difference in texture, I couldn't tell the difference in performance. Darren
Post #821399 26th Mar 2020 9:29am
Perhaps some of you insulation gurus could give me some advice?
I will shortly be removing the droopy headlining from my Disco2 to re-upholster it, it has the usual D2 problem of the foam layer disintegrating so the fabric drops. While the headlining is out, I want to apply some insulation to the bare steel roof since another well know D2 problem is that you get a mass of condensation on the roof which then pools and shoots out of the front seat belt upper mounts straight into your lap (or the passenger's lap) when you set off.
It was my plan to apply some form of thermal insulation (noise really isn't an issue) to try to inhibit the condensation. At the moment my thoughts are self-adhesive closed cell foam, dos the panel think that this would be the best, or is there something better?
Many thanks!
Post #821410 26th Mar 2020 10:01am
Stacey007
Hello
I've used Silent coat with a 8mm solfcell foam on the top.
Maybe overkill but watch this as a demo....
Post #821412 26th Mar 2020 10:10am
keith
Can’t speak highly enough of Silent Coat. Doing my 110 as we speak. I bought the Landrover 90 pack it’s more than enough. Seat box inside and out, underneath floors and bulkhead. Still have spare sheets. Highly recommend.
Awaiting delivery of floor insulation and roof sound deadening.
Post #821416 26th Mar 2020 10:19am
cold
Look up Noico on Amazon, I have used their Butyl sheets and the Red foam - seemed to do the job and cheap in comparison
Post #821442 26th Mar 2020 12:47pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I used noise killer kit and am pleased with the difference.
https://www.nkgroup.co.uk/
Post #821447 26th Mar 2020 1:34pm
donmacn
Many thanks!
Partly because they're just down the road, and I was going to be passing anyway, I went for the option from Lasalle Trim. https://www.lasalle-trim.co.uk/product/110-roof-ta-insulation/
I don't seem to remember paying that much tbh, but maybe. I'm sure there will be cheaper options. Having said that, the stuff has stuck up there and stayed there, and I think the car is warmer and a little quieter as a result. What has definitely stopped is the cold condensation shower that (as you'll know) in the Defender comes out about the middle of the front doors but still ends up in your lap!
I got the 110 kit - maybe three large sheets - and I think I've got most of one of them left, so perhaps a 90 kit would do the job.
Like a lot of these things, if you search about the interweb you might find it cheaper.
For cutting condensation though, I'm happy with this. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #821465 26th Mar 2020 3:15pm
jst
great, thank you. lots of options to research Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #821549 27th Mar 2020 8:23am
Page 1 of 3 123>
