Home > Maintenance & Modifications > Best stick on sound proofing |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Guess anyone would advice on the stuff they stuck on themselves?
Not sure what's the best value but I've bought a complete sound deadening kit from a forum member (mps?) years ago. After only covering the rear behind the rear seats with Dynamat Xtreme and Dynaliner it already made such a difference I never fitted the rest. Who knows if I get bored enough during lockdown... |
25th Mar 2020 10:29pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Silent coat is far cheaper then dynamat but still expensive. It’s cheaper if you buy in bulk and in sheets. Not pre cut.
Some people have used simple rubber mat but I can’t comment on the Results. Silent coat worked for me. recomended by the super helpful blokes at deadening.co..uk |
25th Mar 2020 11:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20342 |
I like Dynamat Extreme in black but there are different alternatives such as above.
There was some talk about some of the cheap stuff possibly containing Lead, I don't know what truth there is in that though. Dynamat may not be cheap but it works, I haven't done much of mine with it but the seat boxes externally and the base made a difference I do know. One day I may do more, I've been telling myself that for about 4 years now. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Mar 2020 1:16am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I’ve used Fatmat on a few vehicles and it performs well. Much cheaper than dynamat too. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
26th Mar 2020 6:58am |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
I bought sheets of dynamat and cut to size , it was also for a double cab . The difference is huge , doors, seat box and floors made were the most noticeable .
I like the dynamat because it doesn’t hold water , I’ve tried other brands and was hugely disappointed that they acted like sponges https://www.instagram.com/hustynminepark/ |
26th Mar 2020 7:08am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2162 |
Fatmat megamat. Cheaper then dyna extreme and basically the same product.
Makes a huge difference, also added some layers of 6 and 3mm closed cell foam over the top. Instagram @defender_ventures Empire Tuning - Agent |
26th Mar 2020 7:20am |
There's a company on eBay - the Sound Deadening Shop or something similar - that sells bulk packs of Silentcoat cheaper than anywhere else that I've found. I've been very pleased with its' performance. Buy a cheap, wall paper seam roller to aid with installation.
If you're planning on using acoustic foam over the dense layer then buy generic unbranded stuff. I've used both Silentcoat branded and generic 6mm foam in two different vehicles and whist there was a slight difference in texture, I couldn't tell the difference in performance. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Mar 2020 8:29am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
Perhaps some of you insulation gurus could give me some advice?
I will shortly be removing the droopy headlining from my Disco2 to re-upholster it, it has the usual D2 problem of the foam layer disintegrating so the fabric drops. While the headlining is out, I want to apply some insulation to the bare steel roof since another well know D2 problem is that you get a mass of condensation on the roof which then pools and shoots out of the front seat belt upper mounts straight into your lap (or the passenger's lap) when you set off. It was my plan to apply some form of thermal insulation (noise really isn't an issue) to try to inhibit the condensation. At the moment my thoughts are self-adhesive closed cell foam, dos the panel think that this would be the best, or is there something better? Many thanks! |
26th Mar 2020 9:01am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3749 |
Hello
I've used Silent coat with a 8mm solfcell foam on the top. Maybe overkill but watch this as a demo.... |
26th Mar 2020 9:10am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2212 |
Can’t speak highly enough of Silent Coat. Doing my 110 as we speak. I bought the Landrover 90 pack it’s more than enough. Seat box inside and out, underneath floors and bulkhead. Still have spare sheets. Highly recommend.
Awaiting delivery of floor insulation and roof sound deadening. Click image to enlarge Click image to enlarge Click image to enlarge |
26th Mar 2020 9:19am |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 118 |
Look up Noico on Amazon, I have used their Butyl sheets and the Red foam - seemed to do the job and cheap in comparison
26th Mar 2020 11:47am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
I used noise killer kit and am pleased with the difference.
https://www.nkgroup.co.uk/ |
26th Mar 2020 12:34pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
Partly because they're just down the road, and I was going to be passing anyway, I went for the option from Lasalle Trim. https://www.lasalle-trim.co.uk/product/110-roof-ta-insulation/ I don't seem to remember paying that much tbh, but maybe. I'm sure there will be cheaper options. Having said that, the stuff has stuck up there and stayed there, and I think the car is warmer and a little quieter as a result. What has definitely stopped is the cold condensation shower that (as you'll know) in the Defender comes out about the middle of the front doors but still ends up in your lap! I got the 110 kit - maybe three large sheets - and I think I've got most of one of them left, so perhaps a 90 kit would do the job. Like a lot of these things, if you search about the interweb you might find it cheaper. For cutting condensation though, I'm happy with this. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
26th Mar 2020 2:15pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
great, thank you. lots of options to research Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Mar 2020 7:23am |
