Home > Puma (Tdci) > Switch Wiring
luke11
2008 Defender 110 Puma 2.4 XS DCPU Tonga Green
Switch Wiring
After some advise,
I finally got around to wiring in the recovery lights on the front of my 110 today, but i can't get the dash switch i bought to work properly.
They are working fine with a togglew switch but io would like to get the proper dash switch to work
I was planning on switching the negative on the recovery lights but when i connect the switch up ( an aux 2 latching dash switch) the indicator LED is always on (dull when the switch is off and bright when on)
Can anyone help..... do you know the pin connections of the switch?
Thanks
Post #81687 23rd Jul 2011 6:50pm
PaulMc
Re: Switch Wiring
The "Aux 2" switch (YUG000540LNF) switches the earth and must be wired-up as designed for the LEDs to light correctly.
All you need to know is in these threads -
http://www.defender2.net/forum/topic552.html
http://www.defender2.net/forum/topic679.html
http://www.defender2.net/forum/topic795.html
. Paul.
Post #81703 23rd Jul 2011 7:54pm
luke11
I'm a bit confused, i thought i'd done eveything correctly.
The switch is turning the lights on and off as it should, it illuminates when the side lights are on, but the orange indicatoor light is on all the time when connected.
Any ideas?
Post #81915 25th Jul 2011 8:03pm
PaulMc
Any ideas?
Could you confirm the part number of the switch you have?
And how you have wired it - which wire goes to which pin on the switch?
. Paul.
Post #81934 25th Jul 2011 9:12pm
K9F
Any ideas?
PaulMc gave you several links to look at....Did you read them? Below is a cut and paste from the first link he posted, think all the information being an electrician myself is all there, bits you need, plus a comprehensive wiring diagram...
PaulMc wrote:
one_iota wrote:
The driving light switch on the far right is part no YUG 000540LNF purchased from www.britishparts.co.uk.
I haven't worked out how to get the switch illumination and on-light to work but at least the driving light switching is working (pins 1 & 4).
That's because YUG000540LNF switches the earth from the accessory's relay and not the feed to it.
If you use it to switch across pins 1 & 4, it will work as a simple On/Off switch but, you won't get either the green illumination or orange 'tell-tale' light to work, as they are LEDs and require the switch to be wired-up as designed.
To help me understand how to wire up my auxiliary lamps, I sat down and drew a diagram showing how the switch is wired internally and then added a basic auxiliary light circuit to the diagram.
The trigger is shown as coming from the High Beam warning lamp, this is for Driving Lamps.
For Front Fog Lamps, this trigger would be taken from the Sidelights or Dipped Beam - depending on local lighting regulations.
The proper Tyco/AMP Connector 347477-1 with 5 x crimp terminals is available from Dingocroft, their Pt No. ZZPLUG01 -
http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01
There's a lot more info here -
http://www.landroveraddict.com/smf/index.p...546498#new
Paul.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #81936 25th Jul 2011 9:37pm
luke11
Any ideas?
I'll need to check on the part number but its an AUX 2 latching light switch, the connections are below
Pin 1 - Negative from the LED beacons
Pin 2 - Dash lights, taken from pin 2 on another switch
Pin 3 - Earth on the bulkhead
Pin 4 - Not Used
Pin 5 - Permanent 12 Volt fused
Thanks
Luke
Post #81994 26th Jul 2011 11:07am
PaulMc
Pin 4 - Not Used
Thanks
Luke
All looks fine, except for Pin 5
A permanent live on Pin 5, will light the Orange 'Tell-Tale' LED permanently, as you describe.
Pin 5 should be powered from the switched positive side of your lamps (see my diagram above), so that it lights only when your lamps have power and are lit.
Edit:
Re-reading your previous post, you mention LED lamps, I'm guessing that you aren't using a relay in your circuit?
If so, then the 'Aux 2' switch, in it's standard form, isn't best suited to your circuit Sad
However, all is not lost Smile
The switch internals can be easily modified to make it a 'live switching' switch, with all the LEDs working properly.
I don't have time to post the details right now, as I'm off out, but I think that I covered it in one of the links I posted previously.
In any case, I'll re-post the details here, later Thumbs Up
. Paul.
Post #82005 26th Jul 2011 12:27pm
PaulMc
OK, here we are Smile
It's easy to convert the 'Aux 2' switch YUG000540LNF to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture -
On the switches that I've modified, I've used a needle file to gently file away the brass track at this point.
By cutting the track at this point, you separate pins 3 & 4
The revised circuit, for your LED lamps (without using a relay), would be as follows -
Pin 1 - Incoming Live from Fused Supply
Pin 2 - Live from Dash Illumination
Pin 3 - Switch Earth (for indicator LEDs)
Pin 4 - Switched Live output to LED Lamps
Pin 5 - Live in from Switch Pin 4 (for Orange 'tell-tale' LED)
You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but, on my modified switches, I've just crimped an extra short length of cable into Pin 4 on the connector and looped it round into Pin 5 on the connector.
I should have shown how the switch comes apart.
The body can be separated by carefully lifting the four tabs (two on each side) on the side of the switch body.
It's not necessary to remove the switch cap to do this, even though it's shown removed in this picture -
Re-assembly is easy, the two halves just 'snap' back together.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #82018 26th Jul 2011 3:08pm
luke11
Thanks for all of your help Paul, i'll be doing this tonight or tomorrow, you've saved me hours of messing around and blowing fuses
Luke
Post #82031 26th Jul 2011 4:28pm
PaulMc
Luke
Happy to help
Let us know how you get on.
Post #82050 26th Jul 2011 5:31pm
luke11
All sorted! Thanks again, next job is rear work lights mounted to the truckman top with a switch at the rear and in the cab!
Post #82433 28th Jul 2011 6:59pm
PaulMc
To 'double switch' your worklights you need to use two changeover switches, wired like this -
This is how I've wired them in my 110, but using rocker switches for now, until I finish my 2002 Dash Console and re-wire.
It is possible to do 'double switching' using a couple of Defender/Discovery II latching switches, but they have to be modified internally.
I'm currently doing this modification to a couple of switches for some rear work lights on my Discovery II.
Another, different, way of doing it using Defender/Discovery II Switches, is to use non-latching switches such as the Heated Rear Window or Heated Windscreen switches (with only a slight internal modification Wink ) and use them to drive a Latching Relay, such as this from Polevolt -
Ref: 72802R
http://www.polevolt.co.uk/acatalog/info_72802R.html
12 volt latching relay, 25 amp with resistor. CO contacts.
Latching relays require a single pulse across the coil to change the state of the contacts. They must be used with momentary switches, as the coil must not be permanently energised. A relay base is not available. Five connections are by 6.3mm spade terminals. A fixing point is provided on the case side. An internal resistor is fitted across the coil to suppress back EMF.
Price each: (9 or fewer items) £16.80 (£20.16 Including VAT at 20%)
Price each: (10 or more items) £15.75 (£18.90 Including VAT at 20%)
Post #82446 28th Jul 2011 8:35pm
