Home > Puma (Tdci) > Programming new Immobiliser key fob (my 2016) ??
Sheepshed
I’ve lost one of keys with fob, the smart two button one with chrome strip down the side.
I thought it would be easy to buy a new key and immobiliser fob and get it programmed by Landrover but for some reason or other they say they have to take both the internal door panels off my defender 90 SW to program the immobiliser.
Is this true as they are quoting over £300 just for coding the new immobiliser fob??
Post #818194 4th Mar 2020 8:39pm
Mdm
talking rubbish .
all they do is plug in and code the new fob
find another dealer
alas hawkeye etc cant do the later defenders
Post #818362 5th Mar 2020 7:37pm
Sheepshed
Thanks for the reply.
Post #818365 5th Mar 2020 7:45pm
Mdm
autologic will do up to 2012 and some 2013 on the older style fobs plus some of the new style cases depending on which version they have. try a few bigger independents perhaps
Post #818366 5th Mar 2020 7:48pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
After you had it done elsewhere go back to the guys you mentioned and let them explain in full detail, over a cup of tea, why they would want to take the door panels off. Just to waste their time. Twisted Evil And throw in something like "Does your quote include removal of the headlining? In the workshop manual for the late MY2016 it says, the ultrasonic sensor in the roof has to be re-adjusted to match a new fob's frequency." Utter nonsense, of course. Just to see the look on their faces Rolling with laughter
Post #818369 5th Mar 2020 8:03pm
Fat Cog
I took my daughters Peugeot key to Timpsons...cheap as chips, programmed & worked a treat.
https://www.timpson.co.uk/services/car-keys Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #818374 5th Mar 2020 8:24pm
Sheepshed
Thank you for all the replies. Apparently there’s some modules connected to the ECU that need replacing, oh and by the way I forgot to add on the 1 , it’s £1300 I’ve been quoted.
From reading on other sites, the immobiliser module was changed in 2015 and the car has to be programmed to the keys.
Still find it all bizarre, luckily the supplying Non LR dealership is paying for this. The irony of it is is that there’s probably some nefarious characters out there that can break in and start my defender without a sodding key and fob.
Post #818397 5th Mar 2020 9:31pm
macfrank
ridiculous
Post #818559 6th Mar 2020 9:03pm
ehoms
Mexico
Well you are lucky. Land Rover Mexico says they need to replace the ECU on my MY2013 90
Post #819366 12th Mar 2020 10:31pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
For some bizarre reason, 2 seperate Timpson booth's cocked up doing a spare key for me.
I had to wait 5 days for them to get the blank in, then they Censored up the cutting and refused to order another key for thier mistake as it was in their words ' abit tricky '
Told to go to LR and get a new key.
Post #819376 12th Mar 2020 11:11pm
Sheepshed
Well took the car to Landrover today. The price excluding new key and key fob was £783. For some reason they had to order 2 new physical keys in and replace the barrel Ignition lock and the door lock. 5 hours labour.
Post #819496 13th Mar 2020 8:22pm
SkyFallSilver
Kuwait
I configured a new key fob through Nanocom was very easy and the new key fob was ordered from an Italian website and programming was a breeze. 2016 Defender 90 Adventure Edition
Post #820041 17th Mar 2020 9:11pm
I didn’t get any problems with Timpsons for key cutting years ago. But I guess it can very much depend on who is doing it and where. No Guts, No Glory.
Post #820043 17th Mar 2020 9:20pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Slightly off, but still on topic, has anyone tried these fellas
https://remotekey.co.uk/land-rover-keys-re...mmobiliser
Ignition key, blipper, fuel cap key and steering lock key are making holes in my pockets.
Post #822405 30th Mar 2020 8:55pm
MK
For those Nanocom experts.
Is it possible to add a used FOB using the Nanocom? If not clear, from one Defender to another one.
I know GAP tool cannot do it with used FOBs
Thanks Puma 110" SW
Post #1019358 27th Dec 2023 12:28pm
