Home > Puma (Tdci) > Programming new Immobiliser key fob (my 2016) ?? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1591 |
talking rubbish .
all they do is plug in and code the new fob find another dealer alas hawkeye etc cant do the later defenders |
5th Mar 2020 7:37pm |
Sheepshed Member Since: 03 Mar 2020 Location: Chesterfield Posts: 12 |
Thanks for the reply.
5th Mar 2020 7:45pm |
autologic will do up to 2012 and some 2013 on the older style fobs plus some of the new style cases depending on which version they have. try a few bigger independents perhaps
5th Mar 2020 7:48pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1070 |
After you had it done elsewhere go back to the guys you mentioned and let them explain in full detail, over a cup of tea, why they would want to take the door panels off. Just to waste their time. And throw in something like "Does your quote include removal of the headlining? In the workshop manual for the late MY2016 it says, the ultrasonic sensor in the roof has to be re-adjusted to match a new fob's frequency." Utter nonsense, of course. Just to see the look on their faces
5th Mar 2020 8:03pm |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
I took my daughters Peugeot key to Timpsons...cheap as chips, programmed & worked a treat.
https://www.timpson.co.uk/services/car-keys Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
5th Mar 2020 8:24pm |
Thank you for all the replies. Apparently there’s some modules connected to the ECU that need replacing, oh and by the way I forgot to add on the 1 , it’s £1300 I’ve been quoted.
From reading on other sites, the immobiliser module was changed in 2015 and the car has to be programmed to the keys. Still find it all bizarre, luckily the supplying Non LR dealership is paying for this. The irony of it is is that there’s probably some nefarious characters out there that can break in and start my defender without a sodding key and fob. |
5th Mar 2020 9:31pm |
ridiculous
6th Mar 2020 9:03pm |
ehoms Member Since: 23 Jan 2019 Location: Mexico Posts: 3 |
Well you are lucky. Land Rover Mexico says they need to replace the ECU on my MY2013 90
12th Mar 2020 10:31pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
For some bizarre reason, 2 seperate Timpson booth's cocked up doing a spare key for me. I had to wait 5 days for them to get the blank in, then they up the cutting and refused to order another key for thier mistake as it was in their words ' abit tricky ' Told to go to LR and get a new key. |
12th Mar 2020 11:11pm |
Well took the car to Landrover today. The price excluding new key and key fob was £783. For some reason they had to order 2 new physical keys in and replace the barrel Ignition lock and the door lock. 5 hours labour.
13th Mar 2020 8:22pm |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
I configured a new key fob through Nanocom was very easy and the new key fob was ordered from an Italian website and programming was a breeze. 2016 Defender 90 Adventure Edition
17th Mar 2020 9:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
I didn’t get any problems with Timpsons for key cutting years ago. But I guess it can very much depend on who is doing it and where. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
17th Mar 2020 9:20pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 |
Slightly off, but still on topic, has anyone tried these fellas
https://remotekey.co.uk/land-rover-keys-re...mmobiliser Ignition key, blipper, fuel cap key and steering lock key are making holes in my pockets. Cheers |
30th Mar 2020 8:55pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2412 |
For those Nanocom experts.
Is it possible to add a used FOB using the Nanocom? If not clear, from one Defender to another one. I know GAP tool cannot do it with used FOBs Thanks Puma 110" SW ............................................................. Earth first. Other planets later |
27th Dec 2023 12:28pm |
