Home > Puma (Tdci) > Averages - and batteries |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
I've got a c-tek (plugged in now as it happens) but I have a tendency to forget / can't be bothered to plug it in regular.
I'm thinking of extending the plug / loop terminals such that the loops are permanently bolted to battery and plug resides under seat for easy connection (would utilise same grommet as for heated seats) will keep an eye on just how long battery lasts but seems average so far is 2-3 weeks. not sure how such a small drain is possible with alarm and other stuff in 'sleep mode' - I wouldn't be surprised if alarm alone was in excess of 10mA ? |
20th Feb 2020 11:15am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
that's exactly what I have done connector is next to the passenger door, I can close the door on the charger cable and the door seal is happy to allow the door to lock DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Feb 2020 7:25pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 |
Wouldn't it make sense to measure electricity consumption at rest first? Roughly it then would be possible to calculate the duration with the capacity of battery.... |
12th Mar 2020 2:05pm |
That’s a cracking secondary use for the snow cowl Really not a fan of putting cables in doors and closing them ~ Landrover doors especially. |
12th Mar 2020 4:25pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8137 |
I dont worry about cables catching in doors, the gap is massive on most defenders. In fact I am not sure my dog wouldnt climb out through the door gaps if she wasnt so well behaved. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Mar 2020 4:40pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
12th Mar 2020 6:27pm |
12th Mar 2020 8:09pm |
it would and I should. what are most people seeing as an electrical load when parked up? |
12th Mar 2020 8:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
Pretty much all Defenders currrent draw at rest parked up varies.
I would say between 12 and 30mA would be pretty typical, you can always test your own Defender with a Multimeter too of course. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Mar 2020 8:21pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1228 |
Exactly, no holes needed drilling in the Defender and easy enough to use without any faffing about. 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
12th Mar 2020 8:23pm |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1286 |
One of the Ninetys I bought came with a little solar powered battery maintainer.
Currently on a Series One diesel, just inside the windscreen with the wires going out the door and under the bonnet. Seems to keep the seldom used vehicle and its (two 6 volt) batteries fresh, but of course, you have to park outside. |
12th Mar 2020 9:48pm |
That's interesting Charles. I keep the fire engine on charge (maintenance). I fired it up last weekend after having to park it up with no access for about 7 weeks. It started but only just. I guess the cold weather of late did not help. 6 volt batteries are expensive so not keen to replace anytime soon! 1984 One-Ten CSW
12th Mar 2020 10:31pm |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 |
For a long storage, you can also disconnect the battery.
13th Apr 2020 3:21pm |
