Home > Puma (Tdci) > Averages - and batteries
Page 2 of 2 <12
Caterham
I've got a c-tek (plugged in now as it happens) but I have a tendency to forget / can't be bothered to plug it in regular.
I'm thinking of extending the plug / loop terminals such that the loops are permanently bolted to battery and plug resides under seat for easy connection (would utilise same grommet as for heated seats) Thumbs Up
will keep an eye on just how long battery lasts but seems average so far is 2-3 weeks.
not sure how such a small drain is possible with alarm and other stuff in 'sleep mode' - I wouldn't be surprised if alarm alone was in excess of 10mA ?
Post #816130 20th Feb 2020 12:15pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
That's exactly what I am planning when I get a 'roundtoit'!
- bit of a pain pitting the CTEK on otherwise but the kit works really well for a tired or unused battery (mine's 10 years old). Richard
Defender 90 SVX
Post #816170 20th Feb 2020 6:42pm
LR90XS2011
that's exactly what I have done connector is next to the passenger door, I can close the door on the charger cable and the door seal is happy to allow the door to lock DEFENDER 90 TDCI XS,
Post #816192 20th Feb 2020 8:25pm
hornet
Re: Averages - and batteries
Caterham wrote:
folk. just wondering what is typical.
I used to use the defender as an everyday motor, although I'm sure there may have been occasions when it was left for a week or so (holidays for example - although can't specifically recall) and always started.
Any advice, suggestions, bench marks etc welcome. Thumbs Up
Wouldn't it make sense to measure electricity consumption at rest first? Roughly it then would be possible to calculate the duration with the capacity of battery....
Post #819278 12th Mar 2020 3:05pm
seriesonenut wrote:
My 110 came to me with a new battery almost three years ago and only now it feels sluggish if parked for over a week or so. Answer CTEK charger via externally mounted 'comfort' connector. I also have the benefit of the LED lights showing the status externally when not connected
ctek by Richard Holmes, on Flickr
That’s a cracking secondary use for the snow cowl Thumbs Up
Really not a fan of putting cables in doors and closing them ~ Landrover doors especially.
Post #819297 12th Mar 2020 5:25pm
jst
I dont worry about cables catching in doors, the gap is massive on most defenders. In fact I am not sure my dog wouldnt climb out through the door gaps if she wasnt so well behaved. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #819303 12th Mar 2020 5:40pm
Co1
Rolling with laughter
Post #819318 12th Mar 2020 7:27pm
Caterham
Thumbs Up
Post #819338 12th Mar 2020 9:09pm
Caterham
it would and I should.
what are most people seeing as an electrical load when parked up?
Post #819339 12th Mar 2020 9:10pm
Pretty much all Defenders currrent draw at rest parked up varies.
I would say between 12 and 30mA would be pretty typical, you can always test your own Defender with a Multimeter too of course. WeWillWin🇬🇧🇺🇸
Post #819344 12th Mar 2020 9:21pm
seriesonenut
Exactly, no holes needed drilling in the Defender and easy enough to use without any faffing about. 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #819345 12th Mar 2020 9:23pm
Slideywindows
One of the Ninetys I bought came with a little solar powered battery maintainer.
Currently on a Series One diesel, just inside the windscreen with the wires going out the door and under the bonnet.
Seems to keep the seldom used vehicle and its (two 6 volt) batteries fresh, but of course, you have to park outside.
Post #819360 12th Mar 2020 10:48pm
seriesonenut
That's interesting Charles. I keep the fire engine on charge (maintenance). I fired it up last weekend after having to park it up with no access for about 7 weeks. It started but only just. I guess the cold weather of late did not help. 6 volt batteries are expensive so not keen to replace anytime soon! 1984 One-Ten CSW
2010 XS USW (sold)
Post #819365 12th Mar 2020 11:31pm
Mongolia
France
For a long storage, you can also disconnect the battery.
Post #825001 13th Apr 2020 4:21pm
Page 2 of 2 <12
