Home > Technical > Interior light not working - Post Dealer Warranty Work |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 |
Check the Interior light fuse (F29) has not blown. 15 amp. Hope it's just as simple as that.
11th Mar 2020 9:40pm |
Hmm, having been through this at the weekend, if the clock and radio are working then it's not the fuse, as they're shared with the interior lights.
Where was the work that it had done located, as that might give a clue where to start looking? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Mar 2020 8:28am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2178 |
depending on the exact work done then have they simply forgot to connect it back up??
12th Mar 2020 9:01am |
K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300 |
the front A-frame was replaced due to corrosion which would have meant the front headerliner dropped (I'm assuming)?
The rest of the work was around the doors, rear door hinge, lower sills and B-pillar... |
12th Mar 2020 12:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20580 |
I'd check behind your A pillar trims. Easy access and you might have a trapped wire.
If nothing is found, it's an easy place to start, nothing ventured nothing gained. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Mar 2020 12:57pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Did you check the rear light? If it's working it might be the front light's plug/bulb/switch/whatever.
If the rear lamp is dead, too: both lamps branch off 1 meter behind a plug above the door. So it's somewhere before that branch, including the plug and the harness behind the A pillar trim as steve suggested. |
12th Mar 2020 2:53pm |
It’s fairly easy to put a screw though a wire on those trims too if not taking care.
I could be barking up the wrong tree but it’s possible in the circumstances. There is also the frame of the lighting fixture that should be grounded. IIRC there is a captive threaded stud and a lock but on there for that, and also the connections for the power supply to the fixture. And the ground switched door connections. The plus side is, all are easy to check on and easily accessible but a Multimeter maybe useful to you as well if you have one. If all your fuses are in-tact then it will likely be a grounding issue which will need to be traced. Seeing as it’s not your fault though, I wouldn’t be very happy rectifying their mistake myself. I have been in a similar position myself in the past and decided like you it was less hassle just to fix myself. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Mar 2020 3:09pm |
