Home > Maintenance & Modifications > Should I treat/paint new galvanized parts?
NineCherries
Scotland 2000 Defender 110 2.5 TD CSW Oslo Blue
Hello all.
I should be replacing the mid cross member on my 2000 td5 110 this weekend with a new yrm galvanized one. I had hoped to do it last Sunday but 20 year old fixings slowed me down a tad and the afternoon I had put aside to do this job very quickly disappeared 🤣 anyway. With the side steps already off the car and all the rear floor fixings either replaced or very well copper slipped I should have the floor up and out of the way within minutes and get onto installing the cross member.
My question is, is there any real benefit to giving the galvanized coating a little help with a coat of metal paint before I fit it or just fit it as is? I was going to give it a paint but then wondered why as it's already protected?
Just wondering what other people's opinions are.
Thanks T
Post #819205 11th Mar 2020 9:37pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
If you can, absolutely. Zinc will still corrode over (a long) time, eventually leaving bare steel to rust, so additional protection delays the onset of this. If you paint it now, it can be easier to touch up or repaint at a later date than it is to renew the zinc. I also think paint helps protect the zinc from stone chips, albeit minimally.
If not, it's not going to be the end of the world. You'll still get a much longer lifespan out of a galvanised part than the original one.
Post #819214 11th Mar 2020 10:39pm
LR90XS2011
Before you paint it you need to clean it well, you generally also need a special primer as well for galvanised steel DEFENDER 90 TDCI XS,
Post #819222 12th Mar 2020 6:28am
jst
I wouldnt bother. It will prob do 20years with no problems minimum. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #819230 12th Mar 2020 7:50am
Mo Murphy
I do like the appearance of bare galv 😊
50 Shades of Pennine Grey
Post #819237 12th Mar 2020 8:33am
roel
Don't bother painting. My galvanised door strips are from 1984. No rust.
Make sure your take care off your chassis where the crossmember is covering the chassis. My 2001 chassis is in a good shape except where the crossmember is sitting. Roel
2003 90 Td5 (2009-now)
Post #819258 12th Mar 2020 10:58am
NineCherries
Magic, thanks for taking the time to reply.
I'll treat the chassis below the crossmember for sure. I was going to treat as much of the chassis as i can thats exposed when i have the floor up too.
Appreciate the advice.
Thumbs Up
Post #819405 13th Mar 2020 10:25am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
There's lots of good (British) stuff for chassis treatment here:
www.bilthamber.com
Post #819413 13th Mar 2020 11:14am
