Home > Puma (Tdci) > Limp mode & Speedometer occationally going nuts |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2108 |
Welcome to the forum and hope that you find the info on here useful!
I had a similar problem with my 2.4 110 - check the relays under the Right hand seat for tightness - mine was a loose relay that had been causing issues for a few weeks but caused me to grind to a halt one day .. A recovery mechanic was called and took less than one minute to diagnose and fix! Hope that helps and is the only problem Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th Jan 2020 8:53am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Mine did the same & it was the connection on the transfer box for the speed sensor, removed, cleaned and reseated & all good since.
HTH Keith |
19th Jan 2020 12:37pm |
Tanndoktorn Member Since: 18 Jan 2020 Location: Oslo Posts: 12 |
Thanks! I had a look at the relays yesterday, took them all out and reseated them after a quick "wash" with an elecronic cleaner spray. Where do I locate the speed sensor? Is it easy to get to?
20th Jan 2020 8:17pm |
Underneath, on the back face of the transfer box, slightly above and behind the handbrake drum.
Keith |
20th Jan 2020 9:00pm |
Is it possible to fairly easy get access to this sensor from inside the the car, through the floor?
1st Feb 2020 4:18pm |
On your back from underneath, I can do it and I'm (allegedly) fat!
Keith |
1st Feb 2020 5:23pm |
I removed the cubby box to get access to it. You must be an octopus to get to the sensor from underneath the car? 😁
I tried to clean the speed transducer and the contact with electronic cleaner spray and my speedometer now died. Guess I found the problem then and will buy a new sensor to see if that fixes the problem 😊 Click image to enlarge Click image to enlarge |
1st Feb 2020 10:07pm |
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 |
I had this. The engine reduces power when it thinks the vehicles stationary, presumably to stop someone over revving it. Broken wire near plug to speed sensor easily accessed from underneath. Easy fix but pain in the arse to drive around for the couple of weeks before i was able to investigate.
2nd Feb 2020 8:25am |
Mine was a poor or dirty connection a few weeks after first clutch change, pulled off the road, got under car wiggled connection and all was back to normal.
Good luck Keith |
2nd Feb 2020 1:03pm |
I just tried to clean it up again, and now it works.
The speedometer works again, but the other reason why I started to search for sensor problems remains: The engine is not running well between 1500-2000 rpms. It seems like it does not get the fuel it needs for brief moments or some kind of limp mode kicks in erratically (on/off at a fast pace) - Excuse my English, I can't find the right words. I just cleaned the MAF and MAP sensors and feel that I got more power in general and smoother running, except for the problem between 1500-2000rpms. The engine seems to run fine at other rpms for the moment. Any idea what to search for next? I'll change the speed transducer when I get a new one to make sure it's 100%. |
2nd Feb 2020 3:59pm |
Update:
A new speed sensor seems to have solved the speedo problem. BG 245 diesel fuel system cleaner seems to have solved the problem between 1500-2000rpms |
6th Mar 2020 8:24pm |
