Home > Wheels & Tyres > Dynabeads
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Dynabeads
Iโ€™ve been trying to balance my 287/75/R16 Cooper STT PROs with dynabeads and so far have had no luck. Big Cry I started by adding 8oz to each tyre and got some wheel wobble. I added another 4oz to the front and still have wheel wobble. Do I keep adding beads until the wobble stops or is it best to go down the conventional route of balancing?
Cheers! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #818507 6th Mar 2020 4:10pm
What speed are you experiencing the wheel wobble? $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #818516 6th Mar 2020 5:04pm
BaronDefenders
Pretty much any speed from 35/40mph upwards. Charlie
2002 Td5 90 (SOLD)
Post #818518 6th Mar 2020 5:09pm
Have you tried giving the tyres a bang to separate, sometimes there can be tyre soap if in new tyres that beads would adhere too.
Also, I found that with mine the balancing effect got better as they had done some miles.
I would discuss with them direct and see what they say. $W33T $0U7H3RN $UG4R
Post #818522 6th Mar 2020 5:36pm
bankz5152
Get them balanced. Never had an issue with mine, done once 30k later on and off road still perfect. Instagram @defender_ventures
Empire Tuning - Agent
Post #818524 6th Mar 2020 5:38pm
BaronDefenders
Will contact dynabeads and see what they.
Yeah I think I probably will just get them balanced. Charlie
2002 Td5 90 (SOLD)
Post #818529 6th Mar 2020 6:25pm
Grouse
I have Dynabeads and they work perfectly - are you sure you donโ€™t have a buckled wheel - I had this and wrongly assumed it was the tyres that needed balancing 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #818534 6th Mar 2020 6:53pm
BaronDefenders
Wheels are definitely fine. They had been balanced with iron adhesive weights and were fine. Charlie
2002 Td5 90 (SOLD)
Post #818540 6th Mar 2020 7:05pm
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
I was having trouble with some BFGs. Help the Dynabeads as much as possible by balancing as well as possible via the normal route. Then either break the rim and pour in the large beads or (spend an eternity*) pouring small beads into the valve. Had no problems since.
*I did it on a cool morning in the shade. Choose your favourite Gas Law, I cant remember which, but dumping the air cooled the valve stem which condensed the moist air around the stem. The small amount of water wasnโ€™t really visible, but stuck the beads together. I worked this out on tyre number 5.
NG
Post #818585 7th Mar 2020 6:49am
BaronDefenders
I think the beads could be clumped but short of pulling the tyre off the bead Iโ€™m not sure how to break up the clumps.
Iโ€™ll probably try and find somewhere that does black wheel weights and get it done conventionally. Charlie
2002 Td5 90 (SOLD)
Post #818607 7th Mar 2020 9:13am
