![]() | Home > Td5 > Engine cut out |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Can you hear the fuel pump running when you turn the ignition on?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Try with fuel cap removed in case of air lock.
How does pump and fuel sound during priming procedure? |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge This is the diagnosis from AA man, crankshaft sensor is faulty, thats the most likely thing he says, recovery truck on its way ![]() This has been one of the worst days... |
check wiring and plug to the sensor also |
othorton Member Since: 22 Jul 2019 Location: London Posts: 104 ![]() ![]() ![]() |
I'd say you've dodged a bullet to be honest.
I had a similar issue which turned out to be the ECU. New CPS = £35, ECU rebuilt = £350 We changed my CPS as a precautionary measure as we thought it might be the issue and it was covered in both oil and fuel from a leaky FPR. CPS is relatively easy to change, though a bit of a ![]() |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
Just for info - to test run TD5 engine, you can use any TD5 engine ECU, you just need to pair it with imobilizer (10AS) in car, and probably set the right type of fuel pedal, to be able to increase engine RPM. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
