Home > Td5 > TD5 Rev counter bulb
Procta
Tonight there, with in minutes away from home, the rev counter bulb just goes out. What bulbs go in these? as I will just replace the full lot while I have the dash apart. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #815725 18th Feb 2020 12:44am
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have just replaced all of mine with this kit
Much cleaner light
Need to order an extra small bulb for the rev counter - you need 5 of the stick bulbs
https://www.classiccarleds.co.uk/collectio...s-509t-286
Post #815745 18th Feb 2020 8:01am
lightning
Not many TD5’s have the Rev counter, l don’t think it was ever a standard fitting and to buy they are around £300
Post #815767 18th Feb 2020 11:18am
Martin
Site Admin
It's a 286 code bulb, 12V 1.2W, all the small Td5 instruments use the same except the clock which has onboard LED.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #815768 18th Feb 2020 11:21am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
They were only standard on the SA spec 147. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #817856 2nd Mar 2020 8:42am
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Were these not an XS standard option. I have one thank god. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #817858 2nd Mar 2020 8:45am
Martin
Site Admin
No, never standard on UK models AFAIK.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #817867 2nd Mar 2020 9:48am
OsloBlue
Oh cool, thanks for that clarification martin.
Interesting that its considered an option. I'm on IG: https://www.instagram.com/osloblue42/
Post #817872 2nd Mar 2020 10:08am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I replaced almost all my dash bulbs with white LEDs from eBay a while back. The exception was the clock which has PCB mounted LEDs. The upgrade of these has been covered in this forum but I've yet to do it.
https://www.ebay.co.uk/itm/183075105394
The rev-counter is visible in this photo (albeit out of focus because the photo was intended to show the effect of the main-beam LED bar behind the aircon grille) but it shows the illumination.
Post #817929 2nd Mar 2020 6:27pm
