Home > Td5 > TD5 Rev counter bulb |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 430 |
I have just replaced all of mine with this kit
Much cleaner light Need to order an extra small bulb for the rev counter - you need 5 of the stick bulbs https://www.classiccarleds.co.uk/collectio...s-509t-286 |
18th Feb 2020 8:01am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2848 |
Not many TD5’s have the Rev counter, l don’t think it was ever a standard fitting and to buy they are around £300
18th Feb 2020 11:18am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
It's a 286 code bulb, 12V 1.2W, all the small Td5 instruments use the same except the clock which has onboard LED. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Feb 2020 11:21am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
They were only standard on the SA spec 147. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
2nd Mar 2020 8:42am |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
Were these not an XS standard option. I have one thank god. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
2nd Mar 2020 8:45am |
No, never standard on UK models AFAIK. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Mar 2020 9:48am |
Oh cool, thanks for that clarification martin.
Interesting that its considered an option. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
2nd Mar 2020 10:08am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I replaced almost all my dash bulbs with white LEDs from eBay a while back. The exception was the clock which has PCB mounted LEDs. The upgrade of these has been covered in this forum but I've yet to do it.
https://www.ebay.co.uk/itm/183075105394 The rev-counter is visible in this photo (albeit out of focus because the photo was intended to show the effect of the main-beam LED bar behind the aircon grille) but it shows the illumination. Click image to enlarge Click image to enlarge |
2nd Mar 2020 6:27pm |
