Home > Td5 > Bleeding clutch issues
theheffman
United Kingdom 2003 Defender 90 Td5 SW Cairns Blue
I have replaced my slave cylinder and drained all the old fluid, and when i top up the master cylinder with new fluid and pump the clutch pedal I do not feel any resistance from the clutch pedal and no reduction in the level of the fluid in the master cylinder.
I was expecting the fluid to be pushed through the system as I pump the clutch pedal, was not going to be hard until I bleed. However is not not appear to be taking any fluid from the master.
any ideas ?
thanks
john
Post #817052 26th Feb 2020 2:17pm
bankz5152
Is the slave valve open Instagram @defender_ventures
Empire Tuning - Agent
Post #817076 26th Feb 2020 5:27pm
theheffman
oh not sure, how do i check this ?
Post #817081 26th Feb 2020 5:41pm
bankz5152
Suggest watching a youtube vid on how to bleed a td5 clutch. Instagram @defender_ventures
Post #817082 26th Feb 2020 5:51pm
htb2
Wales
Need to use a pressure bleeding kit, like an eazibleed
Post #817089 26th Feb 2020 6:21pm
theheffman
thanks all, well try pressure or reverse bleeding
Post #817090 26th Feb 2020 6:24pm
bankz5152
No you dont. You just need to bleed it properly.
Slave cylinder is on the bellhousing. That must be open on order to bleed the clutch. Instagram @defender_ventures
Post #817096 26th Feb 2020 7:11pm
htb2
Wales
OK I will shut up, just found it easier to get air out of high point in the pipework on mine with one.
Post #817105 26th Feb 2020 7:41pm
lightning
Bleeding the clutch on a TD5 can be a nightmare
After doing the job many times l found the best method is to bleed the clutch using a pressure bleeder, which will likely result in a working clutch but a bit too much play in the pedal, so the biting point is low.
So wedge the pedal down overnight which will cause any air in the system to be absorbed into the brake fluid. In the morning the pedal will feel great, but you need to straightaway bleed the system again.
(Otherwise the lower biting point will after a while come back)
If you do the above it removes all air from the system and you will have the best clutch pedal ever.
Post #817350 28th Feb 2020 9:50am
miker
I've managed to do it in the past and I don't have a pressure bleeder, I just ended up doing it a couple of times over a couple of days to finally get all the air out! The first re-bleed happened at the side of the road...
Post #817354 28th Feb 2020 9:59am
Procta
How is the master cylinder? My dad was having problems bleeding his system and it turned out that the master was on its way. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #817484 29th Feb 2020 12:10am
theheffman
i have purchased a master cylinder just in case !
Post #818267 5th Mar 2020 11:40am
theheffman
installed a new master cylinder and bled normally with the help from some helpful children:)
Clutch is now perfect..
Post #819082 10th Mar 2020 10:55pm
Mo Murphy
I always replace master and slave together, no point in mucking about with old bits for the relatively low cost of new.
50 Shades of Pennine Grey
Post #819102 11th Mar 2020 9:58am
