Home > Maintenance & Modifications > Door Seals |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
All, Looks like my Door seals have gone Hard and started leaking onto my carpets (Its already been dumdumed)
Looking at replacements, Any of you used Exmoor trim ones? https://www.exmoortrim.co.uk/front-door-seal.html I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
24th Feb 2020 11:32am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
LR originals are the best replacement, and keep the water out - but expensive.
24th Feb 2020 11:39am |
yeah not going to pay £80 a seal for something that has already gone hard and won't work... I'm on IG: https://www.instagram.com/osloblue42/
24th Feb 2020 11:47am |
the Seals on mine are Genuine LR only fitted 2017... I'm on IG: https://www.instagram.com/osloblue42/
24th Feb 2020 1:06pm |
Yes I can see your problem then and reluctance to spend on original. Mine are 4 years old and still fine.
Hopefully others will have used the ones you have seen and will comment. |
24th Feb 2020 3:52pm |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 |
Slight thread hijack. What do you recommend using to attach the seals?
24th Feb 2020 7:33pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4787 |
A hammer and a block of wood works well
I've only just replaced the genuine seals on my 2002 90 (still serviceable but tatty) and the ones on my 25 year old 110 are tatty but haven't gone hard yet either (will be replaced soon) You may have been unlucky with a bad batch. I've never heard anyone say anything good about aftermarket door seals - especially britpart ones 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th Feb 2020 7:46pm |
Agree - for original seals I used a rubber hammer. They have a metal insert that grips the door frame. Nothing else needed.
24th Feb 2020 9:47pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
Having had a bad experience in the past with aftermarket seals, I would say genuine are the best, I binned the first lot I bought as they were useless and didn't fit properly. The genuine ones were superb and you could really see and feel the difference in quality and they fit straight on, but pricey yes...
25th Feb 2020 7:33am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
If its a 110 use genuine rear seals nothing else fit.
Front door seals Ive had good experience with Exmoor ones. Instagram @defender_ventures Empire Tuning - Agent |
25th Feb 2020 7:37am |
Rear seals are fine, front is different I'm on IG: https://www.instagram.com/osloblue42/
25th Feb 2020 7:37pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1921 |
Been there loads of times and genuine is the way forward.
That do their job well 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
26th Feb 2020 9:01am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
I have replaced my door seals with the genuine ones not long ago after all on this forum recommended they are the only ones that will do the job properly
If your still not decided on which ones, look at the video's that Britannica Restorations ltd do, a good way to find out the good from the bad 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
28th Feb 2020 9:05pm |
