Home > Maintenance & Modifications > Waterproofing a Mantec RAI
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I have a Mantec RAI installed on my 2006 300Tdi.
I want to make it waterproof. I will be sealing all the joints but need some advice.
Firstly, the dump/dust valve.
I would like to keep it as I think it helps on our dusty roads but I need a way to temporarily seal it. markb110 on the Td5 thread suggested a rubber glove and tiestrap.
Or must I just remove it?
What other areas must I pay attention to when sealing all the pipework.
Post #816509 23rd Feb 2020 8:19am
markb110
If you remove it then any damp, rain, or water ingress will still get in with nowhere to go.
The valve is one way only. If you get under your truck and push up on the valve you won't be able to move it as it is designed to dump water when there is no pressure from the outside.
I left mine in place. I thought long and hard about removing it but decided to keep it in place.
I have competed, green laned, pay and play, Marshalled as well as everyday driving in all weather's.
The disposable glove solution is quick and simple and if I need to do that then I would also be in a position where I would need to cover the radiator.
Also I have seen vehicles with raised air intakes fail in water. Just because it was sealed sometime in the past does not mean it still is when it is needed.
Just my thoughts, hope it helps
Mark
Post #816542 23rd Feb 2020 12:03pm
jfh
Thanks.
Yes I know it's a one-way valve, it's just a concern if it will do the job when 14 years old.
Testing if a air intake is still waterproof must be tricky, unless you just block the intake point itself.
Post #816545 23rd Feb 2020 12:17pm
markb110
Shame the designers at the time did not add a thread and offer a screw on cap such as you get to blank off a plastic plumbing pipe.
Back in the day we had to use wading plugs for the bell housing and timing cover but the then people caused issues for themselves by NOT removing them so I guess that is one reason JLR never did it.
You now have my brain ticking over...... Probably stick to the rubber glove as it works though. Credit cards arnt always the solution.... Rolling with laughter
Post #816561 23rd Feb 2020 2:11pm
jfh
Mine still has the wading plugs for both.
I'll look around for a rubber cap, until then I'll use a glove.
Post #816563 23rd Feb 2020 2:22pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
The weakest point is going to be the multitude of joints just inside the wing. Horrible design that is very hard to seal no matter what brand of RAI you have. Best option is a Southdown Very Happy Hold my beer and watch this!
Post #816578 23rd Feb 2020 3:44pm
jfh
I've got some pretty amazing sealants here, will give it my best.
What about the air filter housing. Do I need to work on it too?
What is a southdown?
Post #816583 23rd Feb 2020 3:49pm
markb110
Hi
if you take out your air box you will see some holes in the bottom. I just filled mine with plumber putty.
At the same time I removed the intake vortex and plugged any holes there as well.
Southdown was an independent supplier of parts for Land Rovers before they were bought out by Terrafirma. Their snorkel is no longer available looking at the current catalogue but stock may still be available via other retailers.
The snorkel entered via a hole cut into the top of the wing and connected to a one piece pipe straight to the air box. none of the original LR pipe ducting was used.
Worth noting that it was originally developed for the 200 and 300TDI and as such the internal diameter was narrower than the Mantec version for the TD5.
Hope that helps
Mark
Post #816595 23rd Feb 2020 4:53pm
topless_matt
Mark.
Southdown still trade. I just bought a new one 2 weeks ago direct from them.
Also the piping is more than adequate for a tuned tdci as when you compare the standard air ducting it is smaller diameter than the Southdown.
Just my 2p worth having had my 300tdi over the top of the wing mirrors with the engine running.
I certainly wouldn’t run any other brand of raised air intake if you intend getting wet! Hold my beer and watch this!
Post #816600 23rd Feb 2020 5:10pm
jfh
Thanks. Will work from one point to the end and try to make it perfect.
Unfortunately I am stuck with this for a while. Funds are too low.
Post #816605 23rd Feb 2020 5:32pm
