![]() | Home > Puma (Tdci) > Limp mode, Fault Code P061B-00 - Possible causes? |
Faulty Mass Air Flow (MAF) sensor
There is some foreign matter around air flow sensor Software incompatibility issue Faulty Powertrain Control Module (PCM) |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
clean your maf sensor bit of brake cleaner will do it try a soft brush kids paint brush is ideal . be gentle though
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 266 ![]() ![]() ![]() |
I gave both the MAF and MAP a clean back in November and didn't notice any difference at all but both looked like new. I might try changing it out for a completely new unit this time so I can at least rule that out.
Does anyone know if the 2.4 MAF works with the 2.2 or do you need a different model? Shops seem to be advertising that they are the sameunit |
Well I replaced the air filter and MAF and all seems well so far, in fact it seems to be a bit more gutsy than before so I'm hoping the MAF was on the way out
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
I was told that brake cleaner kills the MAF, there is a specific spray for the purpose.
