Home > Technical > Broke down help
dioliahary
Broke down help
So I get to Dent, in a storm all good, park up went to shuffle the Land Rover and got a grinding noise sounded from the front right hand side and no drive. Played around with the diff lock and could move but grinding, back in normal drive mode no drive. I am thinking transfer box failure. It’s a 200tdi disco with the disco box, going to have to get help to get home but any ideas?
Now in the pub drinking a beer and staying positive 🤨 1990 200tdi conversion 90
Post #815296 15th Feb 2020 8:28pm
grafty99
Sounds more like front diff, CV or drive flange if its grinding but moving in diff lock. Probably best get it recovered Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #815297 15th Feb 2020 8:31pm
htb2
Wales
Not good. Whilst it does not move are either of the propshafts turning when you try to move. If one is then problem is at that end, my money is on front diff, cv joint or drive flange. If no props turning then problem is in transfer box.
Post #815298 15th Feb 2020 8:36pm
dioliahary
Yes tried to look at the props, see if they were turning. Could not see any movement. Money on the transfer box, just curious why it sound from the front offside, but I was in a field with storm Dennis battering the living daylights out of me. 1990 200tdi conversion 90
Post #815301 15th Feb 2020 8:52pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
More likely to be front end, either shaft or diff than transfer box. If a transfer box fails, it is usually terminal and non driveable. Hold my beer and watch this!
Post #815312 15th Feb 2020 10:21pm
dioliahary
I’m afraid it is non driveable now, going to have a nosey at the props tomorrow, 🤨 1990 200tdi conversion 90
Post #815314 15th Feb 2020 10:25pm
You should check the drive flanges first. Easy to look at. WeWillWin🇬🇧🇺🇸
Post #815320 15th Feb 2020 11:46pm
ickle
Were there early 200 tai faults with a drive gear in the transfer box - later ones were cross drilled to allow lube into the gear mesh IIRC?
I think you can see the fault through the PTO window at the back, an early version of the puma adapter shaft failure, world turns, a new generation of engineers appear and make the same mistakes of 25 years earlier! Rolling with laughter
Keith
Post #815382 16th Feb 2020 1:17pm
dioliahary
Front prop turning, rear one stagnant and positive the clink is from the front right hand side. Now on the drive of shame🤨 1990 200tdi conversion 90
Post #815603 17th Feb 2020 12:26pm
htb2
Wales
Let us know what you find
Post #815609 17th Feb 2020 1:18pm
dioliahary
Will do 👍 1990 200tdi conversion 90
Post #815611 17th Feb 2020 1:37pm
topless_matt
Sounds like the front right cv joint to me. Hold my beer and watch this!
Post #815636 17th Feb 2020 4:41pm
dioliahary
Spot on, front right CV joint disintegrated. Going to renew both sides, the half shaft looks in good nick, would you replace at the same time?
Having dark thoughts about selling up after repairing the CV joints. 🤨 1990 200tdi conversion 90
Post #815652 17th Feb 2020 6:49pm
topless_matt
If you’ve just blown apart the race then just slip a new cv on. They are usually the weak point due to the forces through the bearing race. Hold my beer and watch this!
Post #815704 17th Feb 2020 9:47pm
dioliahary
Going to order a front pair up, one shot grease, already cleaned up the area and I think I will stick a bit of paint on to a smarten up , thanks for all the techie replies, qualitee 👍 1990 200tdi conversion 90
Post #815724 18th Feb 2020 1:40am
