![]() | Home > eBay & Bargain Spots > Aldi Car Battery Charger 12.99 |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
https://www.aldi.co.uk/auto-xs-car-battery...0347442700
Don't know how good it is as I use a CTEK |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
I've a couple of these and had them for a couple of years, do the job no problem. just not as flash as some others.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
Do you mean series or Parallel? Putting a 12V battery in series would give you somewhere around 19-24V, which it probably also wouldn't charge!
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4232 ![]() ![]() ![]() |
I’ve got one of 5hose, it works great as a maintainer/topper upper, but takes an age if the battery is significantly discharged. 2007 110 TDCi Station Wagon XS
Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80 ![]() ![]() ![]() |
You are correct! 2003 Defender 110 TD5 SW 2003 Caterham 7 2006 Mini Cooper GP |
Also, if they are like the earlier version, and unlike a CTEK, if you have a power cut, even momentarily, they drop out and go into standby mode.
This one drops to motorcycle mode after a power cut, so it continues charging but at much reduced peak amps. 2007 110 TDCi Station Wagon XS
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
supacat is right I have one and it drops out after power loss still handy though
Does anyone know if this will charge Lithium and/or AGM?
I have motorbikes with Lithium, and my CTEK won't charge them... Thanks in advance! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
It has a cold weather profile with a higher charge voltage which manual says should also be used for AGM. It doesn’t have a setting for lithium. 2007 110 TDCi Station Wagon XS
Lithium is usually in another price category altogether.
OK. Thanks chaps.. Saved me a wasted drive to Aldi
