Home > Maintenance & Modifications > Sun visors
RRUK
Sun visors
Can someone tell me how the sun visors are attached to the headlining? Is it just a nut on the back side of it or is it captive?
From memory they don't fix through the headlining to the body do they? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #471878 12th Nov 2015 10:21am
gilarion
Two machine screws for each visor, those screw into a captive bracket. You will notice on your front headlining, front windscreen edge; there will be four holes line these up with the four captives and the jobs a good en! For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #471881 12th Nov 2015 10:33am
RRUK
Captive nuts held on the headlining or the body? 2016 D4 HSE
Post #471923 12th Nov 2015 1:19pm
gilarion
Captive nuts attached to the roof you can clearly see the location on the pictures below.
Post #471936 12th Nov 2015 2:08pm
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
Thanks I've been wondering this also!
Can you remove the head liner panels without removing all the plastic side trimming panels?
Post #472027 12th Nov 2015 7:32pm
gilarion
Not really, as you risk the chance of damaging it. Removing the side trim is not that involved anyway.
I estimate that to remove the headlining and trim carefully takes about an hour with the right tools. Removal of the interior lights is much easier if you have the right sized socket for the nuts that hold the metal base plate behind the headlining as one of those nuts being so close to the plastic surround is a pain unless you have one of those little screwdriver sockets.
Sometimes the fir tree fasteners will not come out no matter what you try and then you need a fine fret saw blade used without its holder to cut the head off, you can then once the headlining is removed tap out the stem of the fir tree with a punch or similar. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #472035 12th Nov 2015 7:52pm
Hardest job removing the headlining is getting the rear view mirror bracket off !
At least one of the three rivnuts will spin
Post #472146 13th Nov 2015 6:40am
RRUK
Matt,
Yes, been there, done that! 2016 D4 HSE
Post #473470 17th Nov 2015 12:59pm
CarMan
Delayed thread resurrection! What size are the machine screws please Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #814061 7th Feb 2020 5:04pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
They're 6,3x19mm (14 x 3/4“) (AB614061L), but it's a self-tapping, not machine screw.
Post #814073 7th Feb 2020 6:37pm
CarMan
Thanks for the reply, but they are definitely not self tapping and go into captive nuts Thumbs Up
Post #814079 7th Feb 2020 7:09pm
macfrank
Embarassed Different model? Did I missunderstand what screws were meant?
Not these? https://www.lrworkshop.com/diagrams/land-r...sors_53618
Post #814080 7th Feb 2020 7:16pm
CarMan
No you didn't misunderstand, those are exactly the ones and as you can see they look like bolts, which they are, but described as self tapping Rolling Eyes
Post #814082 7th Feb 2020 7:20pm
macfrank
Ok... Question It's a while since I had a closer look but I'll check again.
May take a while though, so if someone else could shed a light on this?
Post #814084 7th Feb 2020 7:30pm
Interesting that the drawing clearly shows Rivnuts (which would mean machine screws) but the description states Spiraloks which would mean self tappers. I suspect a change took place.
IIRC my 2007 TDCi uses M6 machine screws but I can't remember the length.
Post #814085 7th Feb 2020 7:31pm
