![]() | Home > Technical > Blindo Off Set |
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 ![]() ![]() ![]() |
Hi All,
I'm thinking about getting some http://www.silverlinewheels-tyres.com/4x4/wheels/13 in black for the 110. How have the people that have blindo's found them and what off set do they run?? Regards LR09WA |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Blindo Rims are made for the military WIMEK vehicles, so are made to a very high standard. They have a steel insert where the wheel nut meets the rim which gives a big increase in wheel strength.
They come in 2 offsets, one being a +15mm or +25 mm. ![]() Information courtesy of a 'Google Production' and a few minutes of my time! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Google needs correcting.... it's E-WMIK that had the Blindo's fitted.
