![]() | Home > Puma (Tdci) > Power surging & black smoke |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
i dont believe the VCV will give black smoke, it will give hesitant idle until warm.
it is black smoke as excess fuel or black particulates clearing out of the exhaust from what ever was sprayed in it. How many miles since application. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ior Member Since: 30 Jan 2020 Location: Suffolk Posts: 10 ![]() ![]() ![]() |
About 100 miles since the EGR cleaner.
But surely this isn't causing the power surging ? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
EGR sticking closer I would say.
I had no end off issues with mine, and it wouldnβt run nicely at all. Even started playing up 6 months after fitting a new EGR Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
The brand new OEM EGR valve is literally 3 days old so it can't be that.
Have you checked it for DTCβs though? There could well be a carbon deposit back up that has been deposited now in the new EGR. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
I'd be checking for split intercooler hoses or a split intercooler.
Incidentally there is no power on earth the would make me squirt an aerosol EGR cleaner into my engine. Even if it worked (which I doubt) any dislodged crud is going to go straight into the engine. |
Thanks for tip Blackwolf. Will investigate the intercooler. And yep you're right - stupid lazy decision to use EGR aerosol.
I disconnected the MAF this morning and seemed much better - no surging and significantly reduced smoke. I've ordered a new one so hopefully that was the cause. Cheers |
A big thanks to Blackwolf for sussing out the issue.
It was a badly split intercooler pipe causing all the grief. Now fixed and pulling like a train again ![]() ![]() ![]() |
Excellent news, well done.
Blackwolf knows his stuff. ππ»ππ» Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58 ![]() ![]() ![]() |
I am getting black smoke out of the exhaust when I hit 4th gear and up. I have a leak somewhere near the radiator top hose area. Could this be a similar issue for me?
Hi. Yes I suspect it is.
My intercooler hose (near side) had badly split at the "radiator" (intercooler) end. This hose is quite easy to replace. |
Bish Member Since: 11 Nov 2008 Location: Hungerford Posts: 429 ![]() ![]() |
i have a similar issue.
Very low mileage 2.4 (16,000 miles) that surges under acceleration with black smoke. I had a fault code P1103. Cleaned both MAF and MAP but still there and much more noticeable when hot. Split hose, EGR or sticky vanes on a turbo? |
Check the intercooler hoses carefully on both sides - as well as jubilee clips.
Also check the intercooler rad for any split. (might see signs of oil leakage under the rad) |
