Home > Puma (Tdci) > Power surging & black smoke
ior
England 2007 Defender 90 Puma 2.4 XS CSW Caledonian Blue
Hi all - looking for some expert opinions please....
I have a 2007 2.4 TDCi 80K miles.
It's been running fine apart from a VERY noisy EGR valve. So I thought i'd try EGR cleaner (as an aerosol spray into air intake at 1 second intervals until used up). After this I noticed it was power surging when cruising on the motorway. On each surge there's plenty of black smoke from exhaust. So I replaced the EGR valve at the weekend (brand new OEM part).
This has made NO difference to power surge & smoke. Just have a much quieter "chugga chugga" clean cycle from valve.
My plan is to give it a full service (oil and all filters) and replace the MAP and MAF sensor (I did clean both, but no affect).
After reading other threads about power surge, several have suggested replacing the Fuel Vapour Valve (VCV).
Any thoughts please ?!
Ian
Post #812654 30th Jan 2020 9:56am
jst
i dont believe the VCV will give black smoke, it will give hesitant idle until warm.
it is black smoke as excess fuel or black particulates clearing out of the exhaust from what ever was sprayed in it. How many miles since application. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812692 30th Jan 2020 1:29pm
ior
About 100 miles since the EGR cleaner.
But surely this isn't causing the power surging ?
Post #812700 30th Jan 2020 1:47pm
EGR sticking closer I would say.
I had no end off issues with mine, and it wouldn’t run nicely at all. Even started playing up 6 months after fitting a new EGR ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #812705 30th Jan 2020 2:19pm
ior
The brand new OEM EGR valve is literally 3 days old so it can't be that.
Post #812707 30th Jan 2020 2:32pm
Have you checked it for DTC’s though? There could well be a carbon deposit back up that has been deposited now in the new EGR. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #812730 30th Jan 2020 5:08pm
I'd be checking for split intercooler hoses or a split intercooler.
Incidentally there is no power on earth the would make me squirt an aerosol EGR cleaner into my engine. Even if it worked (which I doubt) any dislodged crud is going to go straight into the engine.
Post #812743 30th Jan 2020 6:17pm
ior
Thanks for tip Blackwolf. Will investigate the intercooler. And yep you're right - stupid lazy decision to use EGR aerosol.
I disconnected the MAF this morning and seemed much better - no surging and significantly reduced smoke. I've ordered a new one so hopefully that was the cause.
Post #812812 31st Jan 2020 8:59am
ior
Solved!
A big thanks to Blackwolf for sussing out the issue.
It was a badly split intercooler pipe causing all the grief.
Now fixed and pulling like a train again Smile
Post #814209 8th Feb 2020 6:30pm
Excellent news, well done. Thumbs Up
Post #814224 8th Feb 2020 8:42pm
Blackwolf knows his stuff. 👍🏻👍🏻 ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #814230 8th Feb 2020 9:06pm
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I am getting black smoke out of the exhaust when I hit 4th gear and up. I have a leak somewhere near the radiator top hose area. Could this be a similar issue for me?
Post #817797 1st Mar 2020 8:36pm
ior
Hi. Yes I suspect it is.
My intercooler hose (near side) had badly split at the "radiator" (intercooler) end.
This hose is quite easy to replace.
Post #817864 2nd Mar 2020 9:30am
Bish
2002 Defender 90 Td5 XS CSW Java Black
i have a similar issue.
Very low mileage 2.4 (16,000 miles) that surges under acceleration with black smoke. I had a fault code P1103.
Cleaned both MAF and MAP but still there and much more noticeable when hot.
Split hose, EGR or sticky vanes on a turbo?
Post #818320 5th Mar 2020 5:22pm
ior
Check the intercooler hoses carefully on both sides - as well as jubilee clips.
Also check the intercooler rad for any split. (might see signs of oil leakage under the rad)
Post #818548 6th Mar 2020 7:47pm
