![]() | Home > In Car Electronics > DRLs causing noise on stereo |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Just fitted a new bumper with DRLs from Dixon fabrications. Looks mint.
At the same time I messed on with the stereo and changed the speakers. One of these things caused noise or bad reception with the DAB radio reception. My guess was that speakers but it turns out it was the LEDs on the bumper. Power to them and the radio goes to hiss. Tried everything (I know) to isolate it, but with the led’s lit the reception is pants. Don’t know how to add a video to this or I would. Anyone else had issues with noise from DRLs? These came with the bumper so are obviously cheapies but speaking Dixon they have supplied thousands and never had a problem. I also have one of the cheapy DRL ignition things from the bay that might be an issue. What make does everyone else have that’s proven to be good. ![]() Click image to enlarge Cheers PCM Last edited by PCM on 28th Jan 2020 11:41pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
As above, clamp on ones in-line are ideal. I think I got mine on Amazon in a multi size pack. WeWillWin🇬🇧🇺🇸
Took it Newcastle audio centre for them to have a look as my audio tool kit (and knowledge) was a bit sparse.
Spent a lot of time on isolating the solving the noise issue. We've fitted a selection of ferrite rings. Wrapped the cabling in a special blanket. Removed the cheaply Drl module and wired them directly to the battery and also to an ignition live. All the other led lights don't cause any issues. Just these. Conclusion. The drls supplied are causing a huge amount of interference and there is nothing the audio centre can do to solve it. They said some of them just do. FM not really affected, but DAB is woeful. Great..... ![]() My only option now is to find another more reputable set of Drls that fit the bumper and don't emit dab killing noise. At the moment they are off. |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Have a word with Scott at uproar4x4, he can supply the DRL's you need as your bumper looks pretty similar to mine. I also have the Nakatanenga DAB aerial and zero issues with interference.
Perfect.
Was thinking of trying a few others but if you know of one that fits that works with DAB then great. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
Hope you get this sorted, always annoying when something that should be easy becomes so frustrating. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
It’ll be fine...
I’ll contact uproar and see what they use, but in the mean time I’ve just bought 3 different sets on Amazon for delivery tomorrow.... ![]() one of them must surely work..... Have to say the bumper is awesome..... maybe not uproar stainless but Quality of Dixon fabrication is brilliant. |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
I have a similiar conundrum, fitted a new DAB radio and now when I press the brake pedal, the FM signal goes pants 😡 Was working fine with the old radio. 1990 200tdi conversion 90
The fitter at the audio centre was brilliant. If there was a way to fix the noise issue he would.
In the end they called them DAB restricting lights and I’ve had them turned off. Seems our beloved Defenders don’t handle some of the fancy toys without putting up a fight first. Never heard of the brake causing electrical interference. If it Wasn’t so Annoyingly bad it’d be funny. ![]() |
It's mad, I can only think the brake light switch is causing the interference. The joys 🙄 1990 200tdi conversion 90
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 195 ![]() ![]() ![]() |
Hi I've been using Ring BRL0397 with no issues, comes as a kit with wiring and automatic switching unit
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
When I installed an old Sony radio there were massive interferences when charging an iPhone.
I tried this in the radio's power line: https://www.amazon.co.uk/Sinus-Live-Interf...ast_bbp_dp No change. ![]() Then this in the audio input line: https://www.amazon.co.uk/Sinus-Live-205-Gr...ast_bbp_dp ahh - silence ![]() |
👍 1990 200tdi conversion 90
Mac frank
What do you mean by the Audio Input line exactly. It’s worth a try.... |
