![]() | Home > Technical > 2013 110 Puma 2.2 - low power on first start of the day |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1856 ![]() ![]() ![]() |
I had something similar on a TD5 discovery a few years back. Ran fine but zero power on initial start up but would clear if revved a couple of times before pulling off.
Turned out to be a failing MAF sensor. Swapped and problem fixed. Perhaps you have a similar issue? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 52 ![]() ![]() |
Thanks Rosco! Will give it a shot.
OK, some development...
When I rev up a few times I get back power and can make it out of my driveway but it doesn't feel like it is all there. I've since noticed the following: changing up from 2nd to 3rd or 3rd to 4th, revs are about 3000, as I put in the clutch the revs drop to about 2200 and hangs there for a few seconds before falling. When not driving I can rev to over 3000 and it will drop sharply back to idle when I release the pedal. This happens only when I'm stationary (no load). Any ideas? Could it still be the MAF sensor? |
