Home > Technical > 2013 110 Puma 2.2 - low power on first start of the day
Tumbiri
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Just crossed 60K. On first start of the day only, no power to make it up a slight incline. Temperatures in the range of 26-30 degC. Diagnostics show no faults.
When I do get it to crawl up my driveway onto the road, it needs running about a km before it reverts to normal.
I've tried letting the engine warm up; no help. It sorts itself out after I drive for a km or so. All starts after that are fine.
Perhaps the turbo is not kicking in. Not sure.
Appreciate any comments.
Post #811834 24th Jan 2020 11:38pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I had something similar on a TD5 discovery a few years back. Ran fine but zero power on initial start up but would clear if revved a couple of times before pulling off.
Turned out to be a failing MAF sensor. Swapped and problem fixed. Perhaps you have a similar issue? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #811836 25th Jan 2020 12:33am
Tumbiri
Thanks Rosco! Will give it a shot.
Post #811877 25th Jan 2020 12:59pm
Tumbiri
OK, some development...
When I rev up a few times I get back power and can make it out of my driveway but it doesn't feel like it is all there.
I've since noticed the following: changing up from 2nd to 3rd or 3rd to 4th, revs are about 3000, as I put in the clutch the revs drop to about 2200 and hangs there for a few seconds before falling. When not driving I can rev to over 3000 and it will drop sharply back to idle when I release the pedal. This happens only when I'm stationary (no load).
Any ideas? Could it still be the MAF sensor?
Post #813468 4th Feb 2020 12:18am
