Home > Off Topic > Pressure washers.....what one? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
I have an inherited Kartcher and it's ok but not great with more than a touch of design over functional performance.
Two observations: Our local farmer uses a Kranzle... and he wouldn't allow any substandard piece of kit on his yard. Also a local specialist car workshop uses a Nilfisk… I noticed it as we have a 40 year old Nilfisk vacuum cleaner that appears to be indestructible. As and when I trade up I would look at these two SKIP https://www.defender2.net/forum/topic83242.html |
24th Jan 2020 3:58pm |
Banbury Member Since: 22 Jan 2019 Location: Oxfordshire Posts: 47 |
*I have never tried this - but some Kranzle's allow direct suction - say from a tank etc* From the manual (for the 2160) "Due the suction capacity of its pump (up to 2.5 m suction height, max. hose length 3 m) this high-pressure cleaner can suck in water for cleaning purposes from separate containers or ponds." If you go to this site you can download the manual for any recent machine. You can see if yours supports this method: https://kranzle-pressure-washers.co.uk/collections/ |
24th Jan 2020 5:10pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1321 |
If you have the space to store one and aren't needing portability, then it may be worth considering a 2nd hand commercial hot water variable pressure/steam pressure washer.
I went down this route 15 years ago after getting fed up with low powered, unreliable domestic cold water units. I picked up mine for around £500. It runs on a standard 13 amp plug and heats the water using diesel or kerosene. It has a built in detergent tank and has variable pressure and temperature. On the hottest setting it generates steam which is great for cleaning stone paving slabs and stripping paint of vehicles!! Probably use it every other week for washing the car and it has never missed a beat. It's an Edge Wildcat. I guess it's always a gamble buying 2nd hand, especially with a piece of commercial kit as it could have had a hard life. But touch wood,I have been lucky and it was a good decision. |
24th Jan 2020 6:52pm |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 400 |
Handa engine + interpump pump.
Bomb proof. Mine has lasted 13years |
25th Jan 2020 7:39am |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
For Walfy, I'll start a separate topic in this section about outside taps to avoid hijacking the original post.
25th Jan 2020 1:23pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 300 |
My K4 FC started leaking from the pump housing on Thursday, quick trip to my local Karcher centre who repaired next day.
Three year warranty came in handy. |
25th Jan 2020 5:43pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1927 |
Looking into this a bit more and the Kranzle seems to come out on top with spec and reliability.
Think a Kranzle will be my next purchase! I am a brand hoare but looking forward to ditching the Kartcher! 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
27th Jan 2020 10:43am |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 |
I,too,have a Kranzle.
I bought mine off eBay & it has been brilliant. Proper piece of kit Guy May your life be like toilet paper ; long & useful. |
30th Jan 2020 7:24am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8126 |
^^^ i went down the same route, 15 - 20 years ago, Karacher, runs a treat, cost me £500ish (maybe a bit under) it needed a new hose and burner unit in that time and done alot of washing! hot water washers halved my cleaning time. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Jan 2020 1:31pm |
It's amazing what elbow grease will do:
Click image to enlarge Click image to enlarge Neil J Wood (@AtomicGent) Tweeted: My arms..😫 https://t.co/OA9q3Zlrzs https://twitter.com/AtomicGent/status/1224776938742538240?s=20 |
5th Feb 2020 8:55am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Wow what a transformation supacat 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
5th Feb 2020 8:35pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Well after singing the praises of my Kranzle, I went to use it at the weekend and it wouldn't build any pressure. So it's gone for a service, lets hope it isn't to expensive to fix 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Feb 2020 5:58pm |
Had the bill for a service and repair. Apparently there was a blockage in the hose and a piston needed changing inside. It was down 20bar in pressure. So agreed to repairs and service, all in £200 give or take. Not to bad in my mind, I purchased it used 5 yrs ago for £200, cost me nothing til now so all in I'm down £400.
While it was in for service, I priced up the cost to replace like for like. £1200. So I'm really happy. Should get it back later today or tomorrow 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
14th Feb 2020 12:12pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Just bought myself a Kranzle today, Karcher gave up the ghost a while ago and much research led me to Kranzle. Very expensive but as it is German engineering should prove to be more reliable than the Karcher.
15th Feb 2020 8:57pm |
