Home > Maintenance & Modifications > Heated mirrors
Heated mirrors
This is something I just came across on TMD browsing.
How many of you on here have them? Are they really useful?
Obviously, only of use this time of year like heated seats, but I'd like to know who has them on here and what they think.
Finally, am I right in thinking there is factory style switches now that can be printed for things like heated mirrors to blend in?
Very Happy WeWillWin🇬🇧🇺🇸
Post #811662 23rd Jan 2020 7:58pm
grafty99
Great for more than demisting. They also keep the mirrors clear in the wet Thumbs Up
Wired into the rear heated screen they work a treat Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #811664 23rd Jan 2020 8:30pm
I was going to ask that, I guess the warmth sheds the wet off a bit then.
Interesting you mentioned sharing the heated rear screen switch, I have that on mine but not a heated front screen.
I found separate switches for wiring separately Here.
Looks like an interesting mod for once that is useful and doesn't costs hundreds of £'s.
Mr. Green
How did you find the wire outing though the mirror arm and to the interior? WeWillWin🇬🇧🇺🇸
Post #811673 23rd Jan 2020 9:04pm
Litch
Had heated screen & mirrors on my 90 for nearly 20-years now.
The convenience of the heated screen needs no comment and the mirrors are the type of thing that you get so used to that when they stop working (turned out to be a dodgy earth) you really miss them. ONE LIFE, GET IT!
Post #811675 23rd Jan 2020 9:07pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I've had these fitted for a year or so
https://www.mudstuff.co.uk/defender-heated-mirror-elements.html
Easy DIY link shows wiring route Thumbs Up Just because you're offended doesn't mean you're right.
Post #811690 23rd Jan 2020 9:55pm
Sulisuli
I think Roy5695 has just fitted the Optimill lighted / heated ones Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #811691 23rd Jan 2020 10:00pm
L110CDL
Hi
What happens if you accidentally break your mirror, can you peel off the element and stick it on the replacement Question Clayton.
Keeper.
Post #811700 23rd Jan 2020 10:24pm
Mo Murphy
Well worth fitting. Relatively easy to peel off broken bits.
50 Shades of Pennine Grey
Post #811708 23rd Jan 2020 10:38pm
shropshiredefender
As above - the elements seemed quite tough so re fitting to a replacement mirror should be possible but they are relatively inexpensive. Just because you're offended doesn't mean you're right.
Post #811710 23rd Jan 2020 10:44pm
L110CDL
Thank you to the above Thumbs Up Clayton.
Keeper.
Post #811715 23rd Jan 2020 10:58pm
Roy5695
Optimill mirror arms are brilliantly engineered and look the part, come pre-wires for heated mirrors. You do need to drill holes through your door for a neat install though.
Previous to these I modified my old arms, drilled through the ball joint the mirror head attaches too, then through the rotating part of the arm (the bit that allows you to fold them in)(note- done this way your mirrors won’t be able to fold in due to the cable, the cable would be trapped/cut if the mirrors folded) and out the bottom plastic cap, this then looped under the hinge and through a hole in the door. (I’ll try find some photos)
Wires to my heated screen button via a relay. Work wonderfully on a frosty morning and in the wet spray.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #811725 23rd Jan 2020 11:40pm
Very interesting.
The only trouble is you'd need to buy a lower hinge to match as well. Laughing
Or can you buy the billet arms only to use with factory hinge?
Regarding if the element got broken along with mirror glass, seeing as replacement elements on their own seems to be about £10 - £20 a pair I would see it as an easily replaceable part of needed.
Roy - This is a long shot but do you know what current draw the mirror arm (lights).use for the pair?
It must be somewhere under 1A I would have thought if they mimic the interior lighting.
Glad I started this thread as there seems quite a lot of interest and useful info too.
Not so good for the wallet though. Whistle Laughing WeWillWin🇬🇧🇺🇸
Post #811730 24th Jan 2020 12:33am
Thank you. Thumbs Up
Will take a good read though another night. Wink WeWillWin🇬🇧🇺🇸
Post #811731 24th Jan 2020 12:36am
ericvv
Post #811739 24th Jan 2020 6:47am
Zed
Bearmach make the switch covers but as others have said you may prefer to tap into the heated window instead.
https://bearmach.com/switch-assembly-heate...s-ba-10307 WARNING.
Post #811740 24th Jan 2020 6:57am
