![]() | Home > Off Topic > 4G signal booster |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Plenty of 4G "booster" modems out there ranging from £150 to £300 ish.
I've used a few 4G routers for remote CCTV installs, but fortunately enought they've all had reasonable 4G signal, so the standard router has done the job. Not sure how good the "boosters" are, as they can only boost what poor signal there is there, so they could be boosting interference as well. although being digital hopefully there shouldn't be too much rubbish in with it. I used a TPLink 4G router last week, with an Asda PAYG SIM (50p in the shop) and it worked a treat! just keep topping it up as needed. Lots here: https://www.google.com/search?client=firefox-b-d&q=4g+booster |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Sorry I meant an Ariel to capture the signal then connect to router. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
There are a couple out there on Amazon - https://www.amazon.co.uk/Poynting-4G-XPOL-...amp;sr=8-1
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
We're in a "not spot" and dispensed with BT recently. We went all-4G wireless, ending up with this: -
https://www.broadbandbuyer.com/products/32...1/#content Probably a bit OTT for your needs but we needed the ability to run an external antenna as we're in a bit of a valley. On our phones we barely get any kind of signal in the house but the router, with its external antenna gets an excellent signal, providing 15 - 20 Mbps via a Vodafone and a 3 service. BT managed 3 Mbps at best, when it worked. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I have fitted a 4G aerial and WiFi unit to my motorhome. Fantastic bit of kit, I can run 10 devices off it and it gets full signal 4G, where without the aerial connected I ge zero signal on the same sim.
I run two phones, two iPads, and fire stick off it all over Europe, and so far always worked https://www.motorhomewifi.com/product/4g-r...i-save-25/ Really nice, and knowledgeable couple own it. ![]() ![]() Andy. |
Thanks for the replies they have given me some possibilities. The more I looked into it myself the more confused I got which is probably down to age. Don't make old people mad.
