Home > In Car Electronics > Interior light feed |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20451 |
At the light fitting it’s self. There is a ground nut present.
You may need to do a bit of soldering but you can mimic the factory switching and AS10 control by tapping off the back of the light terminals it’s self. Determine correct polarity. Load needs to be under 1A Max, ideally fused right next to the light fitting in Defender. Then if you need to change the fuse access is there though light fitting hole. It won’t affect the rest of the lighting but you need LED in the LR lights too. As I said keep the load under 1A max which with LED shouldn’t be a problem. When it comes to trailer connection do you have the 13pin connection or 12N and S ? Or just 12N? You might find pics in my gallery somewhere of what I did with my light in the LR. It was done tine ago but should be there somewhere. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
19th Jan 2020 9:31pm |
russgreenman Member Since: 05 Jun 2015 Location: Wiltshire Posts: 13 |
Thankyou ever so much, that’s a great help. Not sure on the trailer electrics, just the standard 7 pin plug but I get the feeling that’s not answering your question!
22nd Jan 2020 6:12pm |
I asked about the trailer plugs because I was wondering what plans you had for that connection. No Guts, No Glory.
22nd Jan 2020 6:45pm |
I think the Ifor Williams canopy is over the load bed of russgreenmans' DCPU rather than a trailer. Darren
22nd Jan 2020 7:15pm |
Oh yes I see that now. I had Ifor Williams trailers and Horseboxes on my mind.
It’s the galv rear canopy over the load bed. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
22nd Jan 2020 7:51pm |
You’ve got it! 👍🏻
22nd Jan 2020 10:19pm |
