Home > Maintenance & Modifications > LED Sidelights |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Are your headlights running on relays?
Either way, there is a resistor which gives a small amount of power to the headlights when the switch is set for sidelight only, you can disconnect it by bypassing the relay behind the dash or disconnecting the resistor. https://www.defender2.net/forum/post314514.html |
25th Jan 2020 1:07pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
^^^^ This. I believe IIRC I had the same issue. Disconnecting the resistor did the trick. Then I fitted sealed blanks to the plugs to seal off once disconnected. Under the drivers side wing on a RHD and a 2 pole econoseal connector if I remember rightly. No Guts, No Glory.
25th Jan 2020 3:58pm |
NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 147 |
Don't mean to derail the thread but always thought the front side lights would make suitable DRLs.
Is this a common mod? |
26th Jan 2020 1:09pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2245 |
Not really common but I've done it.
26th Jan 2020 2:55pm |
chrispaylin93 Member Since: 13 May 2017 Location: Gloucestershire Posts: 14 |
Thanks for your help
1st Feb 2020 8:40am |
