Home > Puma (Tdci) > Alarm keeps going off 2014 2.2 110 van |
1.do you have internal movement sensor up on head liner driver side
this is activated 15 sec after the alarm set, had one that getting wet with condensation from roof and setting alarm off 2. also check key fob battery 3. check your starting battery voltage Last edited by dorsetsmith on 21st Jan 2020 2:03pm. Edited 3 times in total |
21st Jan 2020 1:43pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
A few points where I would start. Disconnect internal sensor, just pull wires out of it, and test if alarm goes off, but starter would be to bypass the bonnet switch and see if that cures it.
21st Jan 2020 1:49pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Thanks very much folks. It was fine until yesterday afternoon, and I do get lots of condensation on the roof, so I'll check those things and report back.
21st Jan 2020 2:08pm |
Famous last words, but the sensor in the cab had condensation on its lead and into the socket. A quick squirt of Bilt Hamber's Ferrosol and it's been all quiet since about 2.30pm, so I think that was it.
Fingers now crossed.... Thanks again for the help. |
21st Jan 2020 7:46pm |
You can just leave the wires out of it if you require a longer test. The alarm still works with it disconnected.
21st Jan 2020 8:00pm |
Thanks Andy. If it wakes up the neighbourhood in the early hours, I'll know what to do!
21st Jan 2020 8:18pm |
Ah bother it. It went off at 5.50am.... (and no, it wasn't being pinched!)
More checks to do I think. |
22nd Jan 2020 6:08am |
Incidentally, if it is the bonnet switch (and the gaiter on mine has disintegrated, so it could be), is there any benefit to sticking with the genuine LR one (AMR2022) or are the pattern ones okay?
Thanks again. |
22nd Jan 2020 6:15am |
Swapped mine for an original part because I like mt neighbours
Andy |
22nd Jan 2020 7:47am |
I think I get the picture...! Looks like I'll have to change a few more ball valves to pay for it.
22nd Jan 2020 8:04am |
Just a quick update to say investigations are ongoing, but I've had to leave the alarm off for the last few days just in case it goes off overnight.
Would simply unplugging the under bonnet sensor still leave the alarm working? I checked it with my multi-meter (far too high tech for a plumber...) and it seems to be making and breaking reliably. I'm also interested to know what effect both a low vehicle battery and a low key fob battery could have. Please be gentle, I'm VERY thick when it comes to electrics! |
26th Jan 2020 9:22pm |
A low vehicle battery could trigger the BBUS , if fitted. It's a siren sound as opposed the main alarm that uses the horn, so it's easy to tell the difference. Darren
26th Jan 2020 9:25pm |
You can’t just disconnect the bonnet switch. You would need to disconnect it and then bypass it by joining the two wire/terminals on the vehicle loom.
26th Jan 2020 10:36pm |
Thanks chaps. I think the main battery is probably okay then as it's certainly the horn sounding. I suspected I would need to actually bypass the bonnet switch.
Any thoughts on what a low key fob battery will do please? Thanks again. The help on here is always first class! |
27th Jan 2020 6:16am |
