Home > Technical > 90 truck cab installation advice |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
I think that all truck cabs are interchangeable from the introduction of coil springs (1983) to the end of production (2016).
In what way doesn't it fit well? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Jan 2020 7:14pm |
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 |
The driver side gap between cab and roof is about 5 mm and looking side on to the door the top edge gets bigger towards the front on driver side
20th Jan 2020 7:34pm |
Sounds like the seal has bunched up under the radius around the corner of the screen and its stopping the bolts clamping it down flush.
Also check that it hasn't been previously over tightened and pulled the inner roof channel down where the captive plates sit 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Jan 2020 7:38pm |
Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 41 |
If you ran a piece of string around the barrel sides along the tub, doors and bulkhead is it all in alignment?
Cab sitting on the location spikes? Ex mod land rover... Is any heavy steel bit bent? |
20th Jan 2020 10:16pm |
