Home > Technical > Door bolt help neaded 110
sconie
Hi all, I'm currently working through replacing the door bolts on my 110 to stainless steel. I've hit a problem with the central lower pillar that the rear doors mount too. I had presumed as with the front there would be an internal nut on the chassis interior rather than a loose nut. However on replacing the the stainless steel bolt in the hole it just spins as though there is nothing to screw into?
I can't see any access to the interior of this pillar so I'm stumped, any advice please.
Post #811008 19th Jan 2020 3:42pm
bankz5152
Underneath. Look up the B pillar is hollow with access underneath Instagram @defender_ventures
Empire Tuning - Agent
Post #811012 19th Jan 2020 4:21pm
ericvv
If I remember well, on both top and bottom inside of the B-pillar there should be a plate welded on with nuts to receive the screws. Pretty sure that is correct as I did the job twice. First going from mild steel to SS, but quickly reverting back to new mild steel with plenty Weicon paste.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #811060 19th Jan 2020 8:05pm
sconie
Thanks, I;ll have a look underneath in the daylight. I'm hoping there is a bold inside as if not then the internal welded nut has broken off whilst removing the bolt! don't know where that will leave my as I still have another rusty bolt holding the door hinge.
Post #811063 19th Jan 2020 8:17pm
You can use conventional nuts on all the B post bolts if need be, but it's a bit fiddly at the bottom. I seem to recall that the nut plates are not retained and fall out if you remove both bolts. They're easy to replace.
Post #811090 19th Jan 2020 10:26pm
Roy5695
On the B pillars the nut plates aren’t fixed to the pillar. They will/should fall out when you remove the bolts.
I refitted mine with nyloc nuts, that little bit more of a faff but means they can’t just be unbolted from the outside. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #811093 19th Jan 2020 11:03pm
sconie
Thanks all. I'll set about it in the morning. Cheers
Post #811095 19th Jan 2020 11:12pm
Stiff1
So is it fair to say if all the plates and nuts are in place correctly you should be able to replace one bolt at a time from the outside without worrying about anything falling away inside?
Post #811247 20th Jan 2020 11:06pm
sconie
Well my 2012 with only 30k had one internal nut seized and only by removing the other three bolts I had enough slack to hacksaw it off. As advised above, you need to get under the pillar with a torch and after cleaning and protecting, add a normal stainless nut to the bolt. So far I've done 3/4 of the 110, however the door side bolts in the kit have came up short! I'm hopefully awaiting longer bolts from the supplying company (ebay)
really enjoying the graft around my first defender and as a biker I love to fabricate, adapt and get over a challenge..... So many plans.... Too little cash lol 😂
Post #811249 20th Jan 2020 11:38pm
donmacn
(Edit - this is a reply to Stiff1s question)
Not 100%. You need to offer the plate/nuts up and keep them in place while you get the first bolt of each hinge to catch, then the second bolt should hopefully find the nut Ok, but even then the plate might need a little jiggle to get into the right place.
The plate/nuts are separate, and not held onto the body in any way. This is obviously what allows the doors to adjust vertically - that the 'floating' nut plates allow the doors to be adjusted up or down. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #811250 20th Jan 2020 11:41pm
