![]() | Home > Maintenance & Modifications > Water ingree |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Look up the Defender water ingress manual, it will give you indications of where to look and how to seal any leaks you may find.
https://www.landroverweb.com/Pdf-files/Man...Manual.pdf It is not a Defender, it is a One_Ten |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
I think you will find they nearly all leak.
The only real solution is to park it undercover in a garage......... ![]() |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
Haha yeah I just thought it would be nice not to have to sit on wet seats now and then.
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 183 ![]() ![]() ![]() |
If it doesn't leak water and oil, it's not a genuine defender, it's a copy
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
I had this on the drivers side. Looking at the join where the roof slopes down didn't show anything but I treated it with several applications of Captain Tolley's and it fixed it.
Note that it's best to keep going over it every 30 min for a few hours as I tried the lazy way of just doing it once but I guess the flex of the roof when driving undid that pretty quick. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
Silvertoolbox Member Since: 13 Oct 2018 Location: Westhill Posts: 43 ![]() ![]() |
Glad I didn't print it out.
So long as bottom half leaks too. Good old 80" was great, wash with hose inside and out! It was a soft top too, so didn't leak at all ![]() Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower) |
