Home > Td5 > A fram ball jont
dorsetsmith
A fram ball jont
Looking for torque setting for 1/2 unf nut bolts have look thought td5 Manuel but can not find it
only ball joint to axle 130 lbft or 176 Nm
thank
matthew
Post #809788 11th Jan 2020 12:31pm
htb2
Wales
Never bothered torqueing them in 40 yrs, just nice and tight will do, as access not best just tighten up and do a pull up on the spanner, assuming your are doing it with truck on the ground not on a lift.
Post #809796 11th Jan 2020 1:33pm
dorsetsmith
thanks just at point wheel back on and getting back ground torque up ball joint to axle and so on
Post #809798 11th Jan 2020 1:38pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Like htb2 says tweak them up good and tight... If you try the figure you quoted, you will strip the threads Rolling Eyes ... There are plenty of reference charts available online which advise on maximum values. Have fun Thumbs Up Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #809808 11th Jan 2020 2:38pm
dorsetsmith
Job finish Thumbs Up
Post #809816 11th Jan 2020 3:48pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I did find the torque settings somewhere (can't remember where) when I did my TD5 many years ago and as previous posters suggest I did strip the threads on one of the bolts before reaching the required torque figure!!
Funnily enough the photo at the begging of the thread is mine (prior to stripping threads!!!). In the end I just used the best of the old ones as it was a weekend and I could not get a replacement.
Post #809818 11th Jan 2020 3:55pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
just do blurt out "click" when tightening and call it done Laughing
Post #809823 11th Jan 2020 4:17pm
dorsetsmith
fond this in older work shop manual 1993 my 115Nm or 84 ft-lb for two 1/2 unf bolts and nuts at rear end upper links to the pivot bracket and ball joint
Post #809847 11th Jan 2020 5:45pm
