Home > Puma (Tdci) > Yet another issue.......
Page 2 of 3 <123>
Stacey007
I had mine just cut out as driving along, all power lost, dials all drop everything off. Then a second later it all turns on... or I just turn the key,
It would do it 3 times in a 10 mile journey or once over a 1000 miles,. No codes showed up.
Simple fix for me was a new key barrel.
Your right though cutting out dead as you go passed a truck on a motorway is no something I look forward to Sad
Sorted now
Post #809318 8th Jan 2020 9:49am
Mongolia
France
[quote="Naks"]Hmmm, could be a dirty fuel pickup in the tank?
Time to drop the tank and inspect it - there could be crud around the fuel pickup, and when you put foot, the increased fuel flow is compromised by the blockage.[/quote]
+1
Post #809521 9th Jan 2020 9:38am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I had this for two years before finding it was the MAF sensor. If you simply un-plug it it will run, and if the problem stops then its the MAF sensor. Mines been fine for 3 years after replacement, best do a pump reset and injector learn as well.
Also does not come up with any codes. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #809559 9th Jan 2020 2:08pm
Adammacky
Ive had the same issue, turned out it was the injector harness plug, water had gotten in and damaged the pins, try starting the engine and while running give the plugs a wobble with your fingers and thats when mine would cut out so when driving if i hit a little bump or something that shifted the plug it would conk out, replaced that and its sorted now.
Took ages to figure it out, sometimes i would drive a 10 mile trip and it would die 6 times within the first mile but then be fine the rest of the journey, other times it wouldnt die once, wound up was an understatement!
Good luck hope you find the fault Thumbs Up
Post #809604 9th Jan 2020 6:57pm
Def Junkie
Many thanks for all the very useful tips Bow down Will run these suggestions by the workshop and let you know what comes up.
Post #810165 14th Jan 2020 7:07am
Markez79
UPDATE:
The issue is still occurring. Evil or Very Mad
I took the Landy to a very good local independent specialist who couldn't find any fault codes plus told me it WASNT the VCV or fuel sensor. He cleaned all electrical parts and it ran well for a period of 2 weeks, however the symptoms happened again this morning:
In a 10 min journey this morning it died 3 times but each time in a slightly different way.
1. Slowing down to allow an oncoming car to pass me. Landy stuttered and died. First warning light to come on just before it died was the Oil. Started immediately at first attempt.
2. At set of traffic lights car was mildly hunting at idle. Went to pull off, lost drive and then lurched aggressively forwards as drive kicked in.
3. When at Costa Drive through (!) car cut out when at idle. Again the Oil light was the first warning light to glow. Car started with no issues at first attempt.
Worth noting the car was cold but symptoms have happened before when car is warm.
Any thoughts?
Thanks
M
Post #812664 30th Jan 2020 10:44am
Huttopia
Ok, quite a few folk have said VCV based on their experience. How did the indie dismiss the VCV so easily?
Post #812666 30th Jan 2020 10:53am
Markez79
Based on his experience, when a VCV 'goes, it goes' - i.e. it wont show up so sporadically. I can go 500 miles with no issues and then 3 occur within a 10 min journey.
Thanks
M
Post #812670 30th Jan 2020 11:11am
ior
England 2007 Defender 90 Puma 2.4 XS CSW Caledonian Blue
kmac wrote:
Markez79 wrote:
Many thanks as ever guys.
Expensive to replace?
Mark
You can get Denso branded for about £60 and unbranded for about £30
You can change yourself - only issue is awkward to access the bolts - there is full thread on here with pics on how to do it and the tool - ratchet wrench with extensions/universal joint
Does the ECU need to be re-programmed when the VCV is replaced ?
Post #812682 30th Jan 2020 12:24pm
dorsetsmith
Thanks
M
fuel tank full or ruining low then your problem starts Question
Post #812683 30th Jan 2020 12:33pm
Markez79
This morning it was half full with Shell V Power.
Thanks
Mark
Post #812691 30th Jan 2020 1:28pm
Thanks
M
He's not had much experience of VCV faults then! Rolling with laughter
Post #812709 30th Jan 2020 2:35pm
Pilgrimmick
As said before, ignition switch can cause this issue. Tried all sorts of fixes, but new switch and no more problems. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #812712 30th Jan 2020 2:53pm
Markez79
blackwolf wrote:
Thanks
M
PM sent!
Post #812864 31st Jan 2020 2:09pm
Def Junkie
Def Junkie wrote:
BenB8man wrote:
blackwolf wrote:
Volume control valve.
You need to have this response as an autoreply really. Whistle
So I've had the VCV replaced (Denzo) but the problem persists. Big Cry
It suddenly loses power (when accelerating hard), does not respond to the accelerator, coasts along and then dies.
Any help much appreciated Bow down
So my issue turned out to be due to a fault in the Common Rail Pump which was replaced and the problem seems to have gone away. I have run it a few days now without the engine cutting out on me Thumbs Up
Post #814566 11th Feb 2020 7:34am
Page 2 of 3 <123>
