Home > Technical > What happened? (shuddering) |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1788 |
Stone in the calliper / disc?
5th Jan 2020 7:55pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Propshaft U.J? Just because you're offended doesn't mean you're right.
5th Jan 2020 8:00pm |
Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 41 |
At the time it seemed like a serious problem, I just don't think it would be from somthing caught in the brakes but I can have a careful look for any fresh scratching/scoring tomorrow.
Front propshaft is only 1000+ miles old, the rear isn't but seems sound. When cruising along at speed everything sounds good. |
5th Jan 2020 8:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
Sounds a big like a failed UJ bearing at a guess from symptoms. No Guts, No Glory.
I fixed a neighbour’s that did this, I thought a bolt holding the handbrake onto the t/box had come out and was jamming in the drum...I was right that time!
5th Jan 2020 8:22pm |
doublecabjon Member Since: 28 Sep 2014 Location: Dorset Posts: 31 |
Greeni suggestion gets my vote, check the hand brake drum fixings. Perhaps try backing the adjuster right off and trying again- obviously being cautious as the hand brake will have little effect if needed.
5th Jan 2020 8:51pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 827 |
sticking handbrake or calliper.
my guess is handbrake binding Have fun be happy |
5th Jan 2020 9:06pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
Panhard rod bush failure ? Can set up a strong juddering vibration and difficulty steering.
5th Jan 2020 9:18pm |
Thanks for the suggestions this sounds like it.
5th Jan 2020 9:45pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8084 |
Jamming cv? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Jan 2020 8:07pm |
I removed the handbrake drum - all was fine. Good opportunity to bench grease the rear propshaft anyway and I saw that the bolts holding the A frame upper link brackets to the chassis were a bit loose which should help explain some clunking.
I don't have any of the typical symptoms of a bad CV. The vehicle turns smoothly lock to lock with no clunking. |
7th Jan 2020 2:39pm |
