Home > Td5 > TD5 MAF failing
dorsetsmith
TD5 MAF failing
No top end a lack power on hills and intermitant not accelerator respond but not every time
Had fuel pump and low presser problems in its history, pump OK 4 bar fuel presser
New MAF two year ago, maybe power supply problem plug in and go for test drive no loss of MAF output BUT still lack power and not accelerator respond
stop removed MAF looks OK but smell bunt Question refit MAF check out put at 750 rpm 55 KG -hr 1.90 v Idea lets work it and see if it holdup 10 min driving re-check out put at 750 rpm 40 - 30 KG-hr max out put driving 230 kg-hr and top of the unit hot
cut long story short fit replacement MAF full power and accelerator respond Exclamation
Post #808648 3rd Jan 2020 10:20pm
doublecabjon
That will be that then! Top fault finding
Post #808649 3rd Jan 2020 10:28pm
grafty99
Was that a genuine or aftermarket MAF sensor?
I've always stuck with genuine because they are supposed to be more reliable than aftermarket Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #808650 3rd Jan 2020 10:28pm
dorsetsmith
genuine
Post #808651 3rd Jan 2020 10:29pm
doublecabjon
Are you using a K&N type filter? If so perhaps a little less dust trapping oil?
Post #808655 3rd Jan 2020 10:56pm
dorsetsmith
No
Post #808656 3rd Jan 2020 11:00pm
roel
Also geniune can fail. Shocked Sometimes the fail completely i.e. no reaction on on different air flows but sometimes like yours just give lower values then they should. Like yours. The problem with that is that is happens over a longer time so you don't directely notice it till it gets real bad. Roel
2003 90 Td5 (2009-now)
Post #808742 4th Jan 2020 6:16pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
You get 2 yrs warranty with genuine LR parts!!
Post #808859 5th Jan 2020 5:50pm
dorsetsmith
yes but one mouth out side
Post #808869 5th Jan 2020 6:40pm
