![]() | Home > Technical > Washer jet nozzle maintenance. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
What I do to prevent clogging of the washer jets is to add a tot of vinegar to the washer bottle.
And yes, keep a pin handy to unclog the jets ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10874 ![]() ![]() |
I'm thanking you now as the red TeePee works a treat, mine lives in the " ashtray " with various coins ![]() I mentioned this cleaning method to my work colleague and sadly the red TeePee is to big for his L200 twin cab ( 65 MY ), but the next size down which is an orange one does the job perfectly and if you need the next size down from the orange one, that will be the pink TeePee ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20616 ![]() ![]() |
I use one of these:
https://www.ebay.co.uk/itm/365303663811?_s...BMkqyzoopl Which is a bit like an iPhone sim tool tool, ideal for adjusting the jet angle and pretty much keeps the nozzle clear. The one I have might have a handle that’s a bit smaller than that link though. I find the best way of avoiding clogging the nozzles up, is be sure that debris doesn’t get in there in the first place, and secondly avoid tap water as that’ll encourage the nozzle to corrode. Which is why I use Rain X pre mixed washer fluid. Everyone has their own ways, likes and dislikes but if you do use a water transfer container, make sure it’s double rinsed out first, like a plastic milk bottle. Because if you don’t rinse it out first a couple of times or another container that’s been sitting about a while you can bet it’ll have something in the bottom of it, then that’ll go in the washer fluid bottle, then guess where that’ll go straight up into the nozzle and block one up. ![]() I do think LR could have fitted a bit better washer pump though for sure. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
