Home > In Car Electronics > Reverse Cam Cable Routing |
Hello folks,
I'm planning to install a new head unit that incorporates a screen that can take a feed from a reversing camera. The cable from the camera can be easily routed around the inside of the roof and down one of the A pillars but I'm not sure where to go from there. I haven't had the need to dismantle a Puma dashboard yet so I wonder if anybody has any ideas on how to get from an A pillar to the head unit? How much do I need to dismantle to find a route through? Any pointers (or pictures!) would be much appreciated. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Jan 2020 6:20pm |
Ah ok, thanks. That all sounds more straightforward than I thought it might be.
I had a pair of those MUD A pillar trims in my hand at the Peterborough show but decided against them. Obviously wish I hadn't now Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Jan 2020 8:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
They are good, but depends if you need them or not.
What sort of dia cables are you thinking of fitting? You can probably get away with one or two 4mm max, but beyond that then the Mud trims come into their own. IIRC, they give you around 10mm extra more than enough. In my case I had plenty of wiring behind there already at max capacity on standard trims. I had a 6mm RCA and other wires to fit as well and the Mud trims accepted that with ease. If you'd like any fitted pics, if you can't find any already on here give me a shout as I could easily snap a couple of pics tomorrow anyway as I'll be working on my 90 tomorrow. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
2nd Jan 2020 8:31pm |
I'm not sure, off hand. It'll be a standard video cable, the sort with a yellow RCA plug on. It'll probably fit, to be honest. I just need to make sure it doesn't clash with the rear washer pipe. Darren
2nd Jan 2020 8:40pm |
You might find the other side from the washer fluid pipe there may just be room.
The tricky parts is avoiding crushing anything. Good luck. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
2nd Jan 2020 8:54pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1225 |
Hi
I managed to get two cables down that route, a bit tight but they fitted. Not clear shots but you get the idea Click image to enlargemonitor by Richard Holmes, on Flickr Click image to enlarge20170903_120156 by Richard Holmes, on Flickr Click image to enlarge20170903_122501 by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
2nd Jan 2020 8:57pm |
Ah, excellent, thank you. I also plan to install a very similar camera in that position, too. Darren
3rd Jan 2020 8:03am |
