Home > Tdi > Transfer Box Help Please |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Is there more clearance if you move the lever but if IIRC its top off box only a few bolts so quick and easy.
28th Dec 2019 1:01pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
Cheers fella, moving the lever didn't help. Will there be a gasket to replace if I whip the top off?
28th Dec 2019 1:06pm |
Yes gasket there, down to luck if it gets damaged removing cover, never replaced one yet, dab of hylomar and normally ok as not immersed in oil only splash lubed.
28th Dec 2019 4:30pm |
Perfect, thanks again. luckily I can take off the bits I need from my other block. Looks like the position of the connector at the other end of the rod was wrong which might have been putting undue pressure on the yoke.
28th Dec 2019 5:10pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10751 |
How are you getting on Fatbaron 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
30th Dec 2019 8:47pm |
Time is the greatest hurdle! I've booked off Friday and Saturday to get as much done as I can!
31st Dec 2019 9:27am |
Hope it all goes well for you 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
31st Dec 2019 8:09pm |
