Home > Tdi > Transfer Box Help Please
Fatbaron
Merry Christmas all. I've managed to snap the yoke that connects the operating rod from the transfer selector to the transfer box, see attached pic.
I can't get the pin out that holds the yoke on cause its hitting the side of the housing. Am I being stupid? Is there a specific way of doing this or am I going to have to take off the top of the transfer box?
Cheers in advance. Thumbs Up
Post #807857 28th Dec 2019 12:35pm
htb2
Wales
Is there more clearance if you move the lever but if IIRC its top off box only a few bolts so quick and easy.
Post #807861 28th Dec 2019 1:01pm
Fatbaron
Cheers fella, moving the lever didn't help. Will there be a gasket to replace if I whip the top off?
Post #807862 28th Dec 2019 1:06pm
htb2
Wales
Yes gasket there, down to luck if it gets damaged removing cover, never replaced one yet, dab of hylomar and normally ok as not immersed in oil only splash lubed.
Post #807876 28th Dec 2019 4:30pm
Fatbaron
Perfect, thanks again. Thumbs Up luckily I can take off the bits I need from my other block. Looks like the position of the connector at the other end of the rod was wrong which might have been putting undue pressure on the yoke.
Post #807880 28th Dec 2019 5:10pm
L110CDL
How are you getting on Fatbaron Question Clayton.
Keeper.
Post #808144 30th Dec 2019 8:47pm
Fatbaron
Time is the greatest hurdle! I've booked off Friday and Saturday to get as much done as I can!
Post #808201 31st Dec 2019 9:27am
L110CDL
Hope it all goes well for you Thumbs Up Clayton.
Keeper.
Post #808273 31st Dec 2019 8:09pm
